check gages c4
Old Oct 23, 2007 | 09:18 AM
pb222's Avatar
pb222
3rd Gear
Default check gages c4
has anyone ever had or know what Check Gages message means on a C4
Old Oct 23, 2007 | 10:16 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
What year ??
Old Oct 23, 2007 | 11:09 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Originally Posted by AGENT 86
What year ??
It means you should check your gauges cause one is high or low
It could even be low on gas
Old Oct 23, 2007 | 12:01 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
From the '96 owners manual:
Check Gauges Light:
This light will come on briefly when you are starting the engine.
If the light comes on and stays on while you are driving, check your gauges to see if they are in the warning areas.
This light can come on for:
High Engine Oil temperature or Low Oil Pressure
High Coolant Temperature
High or Low Battery Voltage
Low Fuel Level
High Automatic Transmission Fluid Temperature
Old Oct 23, 2007 | 01:05 PM
kalister1's Avatar
kalister1
I entered a limited access highway (RT 100) my right foot got a cramp, I could not lift it off the go fast pedal. After the car went past 80 MPH (man did that cramp hurt) The first traffic light at the end of the highway turned Yellow. In my hast to stop I stood on the brakes. When the car came to a stop my oil pressure gage went to 0 (ZERO). The car stopped hard! I noticed my Check Gages Light was lit up. I think all the oil washed forward in the pan and the pickup went dry?
But the Check Gages light was on, I guess because of the oil pressure?
Old Oct 23, 2007 | 01:45 PM
RollaMo-LT4
Well, that is one of the reasons listed above.
To check gages c4
