single plane
Old Oct 25, 2007 | 03:37 PM
cruiserto's Avatar
cruiserto
Default single plane
[IMG]
Old Oct 25, 2007 | 06:31 PM
rickneworleansla's Avatar
rickneworleansla
Originally Posted by cruiserto
[IMG]
hmm.. Can't see the picture.
Old Oct 25, 2007 | 07:06 PM
chriswtx's Avatar
chriswtx
Old Oct 25, 2007 | 11:23 PM
comp's Avatar
comp
Old Oct 26, 2007 | 10:38 AM
AKS Racing's Avatar
AKS Racing
Originally Posted by chriswtx
I would like to see what the intake looks like without the aircleaner. Then maybe I would have a better idea of what he did.
Old Oct 27, 2007 | 05:01 PM
pr0zac's Avatar
pr0zac
you got to be friggin kidding..
Old Oct 28, 2007 | 03:05 PM
Curveit's Avatar
Curveit
Looks like a good idea to me. Maybe a bigger diameter housing; if possible, would be even better. It's probably a 4-BBL Throttle Body, for those who don't know. As with a Carb, heigth under the hood is limited for Air Filters.
Old Oct 28, 2007 | 03:14 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Makes sense to me.
Looks to me that the air cleaner is up front in the stock location.
What looks like an air cleaner on top of the manifold, is just one that's been modified to act like a giant banjo fitting. Like this one.
Old Oct 28, 2007 | 04:35 PM
redrose's Avatar
redrose
can't tell how good it looks till we see a 1/4 mi slip...right now just looks like a late 80's pik-up tbi with 6 more injectors.
Old Oct 31, 2007 | 04:09 PM
cruiserto's Avatar
cruiserto
Default nope not kidding
the engine is a 383 with trick flow 23 degree heads. to me it made no sense to use a tpi OR ANY KIND OF RAM intake knowing their limitations and low end torque capabilities (which I'm sure are high on the low end )since i have plenty of torque already on the low end . its a Weiand single plane intake with injector/nitrous bungs drilled out for injectors good for 6500rpm with a 1000 CFM 4 BARREL THROTTLE BODY . it is totaly tuneable with a lap top useing accel dfi
Old Oct 31, 2007 | 05:20 PM
Pelleplutt's Avatar
Pelleplutt
I like it.
The cost for the 4bbl throttle body is the only downside.
Pelle
-90 vert ZF6
Old Oct 31, 2007 | 06:02 PM
chriswtx's Avatar
chriswtx
Have you dynoed it? Whats the RWTQ and RWHP... Post a graph if you have it...
Old Oct 31, 2007 | 08:39 PM
cruiserto's Avatar
cruiserto
Default really
I like it.
Pelle
-90 vert ZF6[/QUOTE]
since i put this together 3 years the price of a 4 barrel throttle body with iac has come down ,I am pretty sure you can get a holly for around $500 the intake is $125 @ summit I dont think you could get the preformance form other corvette setups at any way near that price
Old Oct 31, 2007 | 08:50 PM
cruiserto's Avatar
cruiserto
Default about what?
Well ok it doesent look like a conventional corvette set up, but if you
are into preformance you would understand
Old Oct 31, 2007 | 09:00 PM
cruiserto's Avatar
cruiserto
thanks! your right it is a 1000 cfm 4 barrel throddle body "bigger diameter housing"? if you mean the the thing that looks like an air cleaner its just a houseing the pipe in front of it attaches to a c5 inlet hose and to get more cold air in note the fabricated piece to get more air from the modified c4 filter housing
Old Nov 1, 2007 | 09:40 PM
pr0zac's Avatar
pr0zac
well for the money spent under it i wouldn't top it off with that. i would have done an elbow into a stock style throttle body or a drop base filter.
Old Nov 1, 2007 | 09:57 PM
chriswtx's Avatar
chriswtx
How about something like this...
Check out the flat torque curve on this tunnel ram..
To single plane
Old Nov 1, 2007 | 10:14 PM
anesthes's Avatar
anesthes
If this fit under my vette hood, I woulda kept it.
Old Nov 1, 2007 | 10:23 PM
AKS Racing's Avatar
AKS Racing
But something very similar does.
It all fits under the stock hood in an '87.
Aaron
Old Nov 1, 2007 | 10:26 PM
chriswtx's Avatar
chriswtx
Nice!!!I want to stick a turbo under my hood one day...
