Bad ECM cause emissions failure?
Old Oct 27, 2007 | 08:52 PM
sonomacrew01's Avatar
sonomacrew01
Default Bad ECM cause emissions failure?
I've recently swapped to heated O2's due to long tubes. I thought I needed to do so because the left drivers O2 MV reading was slow to change. Not to mention, the engine went in and out of closed loop. After installing new heated O2's, there was no change. Even swapping the heated O2's themselves, no change.
Is this an ECM problem?
Old Oct 27, 2007 | 09:44 PM
CFI-EFI's Avatar
CFI-EFI
Do you have the ECM powering the O2 heaters??? The ECM doesn't control the O2 output. It's the other way around.
RACE ON!!!
Old Oct 28, 2007 | 08:46 AM
sonomacrew01
I have them powered off of the 12v fan relay (power source used for the electric water pump. I've followed the instructions from this website.
http://sethirdgen.org/HO2S.htm
Bought the same sensor and connector. I understand that the O2 sends a signal to the ECM to adjust fuel mixture ratio. However, if there is a problem with the ECM, would it alter the MV reading or just not read at all? It is a remanufactured ECM.
To Bad ECM cause emissions failure?
