I know it's easy but once again I'm confused.Why would anyone fit an overdrive pulley to any ancillary? why would you want to spin it faster? I know companies like March make underdrive pulleys to save wasted HP on alternators and power steering but I've never heard of anyone trying to spin them faster .
I know it's easy but once again I'm confused.Why would anyone fit an overdrive pulley to any ancillary? why would you want to spin it faster? I know companies like March make underdrive pulleys to save wasted HP on alternators and power steering but I've never heard of anyone trying to spin them faster with a bigger pulley.
March has a Power and AMp series, that gives you the best of both worlds - just don't over do it or the results will be similar.
2nd hint: the problem that created this is in this pic
1st hint:
typical stock cs130
The 3 things that fail
1. electronics from the furnace in the back
2. The rear bearing cooks and looses its grease and fails
3. The plastic internal fan gets brittle from heat cycles and blows.
Yours
The cheasy plastic rear case fan grenaded.
Thats the reason "good" aftermarkets have a metal internal fan
Here's your bingo.
You tryin' to get more amps from the alternator? Smaller wheel, more rev's in the alternator, less power to the wheels???
Or are you tryin' to get more output from the motor? Bigger alternator pulley, less alt rev's, more power to the rear wheels???
You're not confused stauger; you hit the nail on the head.
some alternators at vehicle idle don't spin fast enough to keep the amps/volts up where they sould be. putting on a smaller drive pulley will allow the alternator to spin at a faster speed at a given engine rpm as compared to stock. i have and run a smaller pulley. could really use a higher amperage alternator instead of stock but, this does ok in the mean time.
divide your crank pulley diameter by the Alt pulley diameter
then multiply by the max RPM your going to run. DO NOT EXCEED 18,000, if your number is higher you need to address your pulleys
that info was provided with the powermaster alt, but what was really interesting was they said exceeding the 18,000rpms the cooling fan could distort and contact the belt
