Alternator carnage w/ pics
Oct 28, 2007 | 08:54 PM
Let's see who can guess what caused this damage first
Oct 28, 2007 | 09:11 PM
Looks like the one I got from Advance. First time the motor saw 6000 rpm, it did that.
Oct 28, 2007 | 09:12 PM
St. Jude Donor '05
Bearing failure? M-80? Kopbvet get ahold of it?
Oct 28, 2007 | 09:15 PM
I dont know where this unit came from, it was on the car when I bought it
Quote:
Originally Posted by
Spankyellow
Your guess is in the ballpark
Reason: typo
Oct 28, 2007 | 09:16 PM
cuisinartvette
Oct 28, 2007 | 09:18 PM
2015 C5 of Year Finalist
Was the pulley out of alingment?
Oct 28, 2007 | 09:22 PM
biggrizzly
No it wasn't
Oct 28, 2007 | 09:23 PM
My first one was a lifetime guaantee unit. It lasted a week with the mini ram. Locked up. The replacement was in the car 1/2 hour when the little plastic fan exploded. They replaced that one but I did not even install it. Went to the Zone and bought a NEW one. Got about 5k HARD miles on it.
Oct 28, 2007 | 09:27 PM
Spankyellow
the one in the pics had to have 200 passes on it and at least 5k on the street, but it didnt last in front of the 383
Oct 28, 2007 | 09:32 PM
The alternator never entered my mind as needing an upgrade when doing performance mods.
I hope you got a good replacement.
Oct 28, 2007 | 09:44 PM
The cure partially
This is the upgraded alternator that I put in,a Powermaster 140@ that was a direct replacement
Oct 28, 2007 | 09:47 PM
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Is it because you used the AIR bypass and had no bracket behind the alt to hold it in place?
Oct 28, 2007 | 09:48 PM
jsup
No it is not, the alt is supported in the rear
Oct 28, 2007 | 09:50 PM
Looks like you got a good one.
Oct 28, 2007 | 09:51 PM
2nd hint: the problem that created this is in this pic
1st hint:
Spankyellow
First time the motor saw 6000 rpm , it did that.
Reason: added text
Oct 28, 2007 | 09:52 PM
Spankyellow
the price we pay to go faster
Oct 28, 2007 | 09:59 PM
Is that an overdrive pulley I see in that pic?
Oct 28, 2007 | 10:08 PM
Spankyellow
That beoitch spun to to almost 20k
Oct 28, 2007 | 10:11 PM
To measure your Alternator speed in rpms
divide your crank pulley diameter by the Alt pulley diameter
then multiply by the max RPM your going to run. DO NOT EXCEED 18,000, if your number is higher you need to address your pulleys
_twisted_
Yea, I have one of those too.
It's amazing what we do for a little more power.
