Please, just a simple answer...
Old Oct 29, 2007 | 07:27 PM
joseph p's Avatar
joseph p
Default Please, just a simple answer...
I need injectors for an '89 350 TPI....I used CruzinPerformance for rebuilding injectors on another car and he was terrific. My problem is that he won't rebuild '89Multec injectors because of their solenoid issue.
Fine, so I still need to get injectors, stock spec. injectors. I don't want to tune my fuel pressure to accept a higher PSI injector. I don't want somebodies questionable used/restored business injectors. I want 100% replaceable, injectors.
What's good? Where can I get them?
Racetronics says they have a new injector that does what I want...but they don't know when they'll be available.
Should I just buy Standard injectors( all things considered, I guess I should order injectors for an '88 instead of an '89...right?) from my parts store?
I need to do this quickly, and I'd appreciate your advice.
Thank
Old Oct 29, 2007 | 09:03 PM
joseph p's Avatar
joseph p
Anyone??
Old Oct 29, 2007 | 09:16 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default 89 vette
I replaced my injectors on my 89 a couple a years ago. Bought them at auto zone for around 300 bucks for 8. They are still working perfect. I thought the 89 injectors were better than the 88's. Just my .02
Old Oct 29, 2007 | 09:21 PM
joseph p's Avatar
joseph p
That's what I'm thinking....Rockauto has STANDARD MOTOR PRODUCTS Part # FJ47T {TRU-TECH} for $38.79
Sounds good to me, but what do I know?
http://www.rockauto.com/catalog/x,ca...,parttype,6224
Old Oct 29, 2007 | 09:32 PM
Livin the Dream's Avatar
Livin the Dream
I used the new style accel from summit on my 88 with no problems and about 2k miles on them
Old Oct 29, 2007 | 09:49 PM
joseph p's Avatar
joseph p
Are you speaking of the ACC-150819 , for $275.95?
Old Oct 29, 2007 | 10:13 PM
CorvetteMike2024
Corvette Enthusiast
Default Rock Auto
I buy from rock auto too. I shop around first, and if the shipping doesnt kill the deal, I buy from Rock auto.
Old Oct 29, 2007 | 10:41 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I believe you are looking for 22# injectors (rated at 43.5psi).
These should be a direct replacement for you. They actually only flow about 19#/hr on the car due to GM's operating pressure, but that's beside the point.
Check www.fiveomotorsport.com. I think the Bosch "pink tops" may be 22#.
I thought there was a guy selling new Bosch injectors on ebay for dirt cheap but couldn't find his username. 22# isn't as common as the other sizes.
Old Oct 29, 2007 | 10:47 PM
JohnyH's Avatar
JohnyH
Nope, other way around 88's were the ones to use!
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I used Accel 24 lb injectors, they seem fine, no problems.
Old Oct 29, 2007 | 11:15 PM
1990Redcoupe's Avatar
1990Redcoupe
Many people on the forum, including myself, swear by the Ford Pink Tops. They are fairly inexpensive and work really well. I did a quick search of Ebay and fiveomotorsports but could not find any advertized
I belive the part # is Bosch 0280150561 D9B-22lb On Ebay they typically sell for $150 per set. At a retailer they are $225-$250 or so.
They are plug and play.. direct replacment. The hardest part is getting to the fuel rail.
Good luck.
Old Oct 30, 2007 | 08:37 AM
bd2626's Avatar
bd2626
http://www.injectors4u.com/fuel_injectors.htm
I would buy from them again....good luck
Old Oct 30, 2007 | 09:34 AM
Sam Lam's Avatar
Sam Lam
Joe: I think you are looking for someone to tell you what you should do and I do not think you will get that answer here Here is a thread that has a lot of info on the question you are asking:
http://forums.corvetteforum.com/show...post1560357682
This is a very long thread. Digest the info, send some PMs to people in the above posts for additional info and then make up your mind what you want to do.
I have heard some very good comments on the new Accel injectors. However, the old style are a questionable purchase. I hope this is helpful to you!
To Please, just a simple answer...
