Major Repair?
Old Oct 30, 2007 | 12:44 PM
chanchett's Avatar
chanchett
Default Major Repair?
I just took my 88 corvette into the shop last week because it was spitting coolant all over the place. Originally, the shop thought this was caused by a broken lower intake manifold gasket. Unfortunatley, I got a call this morning saying that that gasket was not the problem and it was primarily caused by a break in the back left bank of the cylinder head. (I hope I got that verbage correct.) Either way, he quoted this work at 11 hours and $1300. If I weren't getting ready to close on a house this Friday, I may consider having the work done, but I really can't afford to pay that right now.
Does $1300 or 11 hours of work sound like it would be in the ball park to fix at a shop? What all is involved if I ever decide to tackle this fix in the future?
Thanks for your input.
Old Oct 30, 2007 | 12:57 PM
rick lambert's Avatar
rick lambert
well, it sounds a little pricey but if they're including a new head(if that's what it is, and I'd want to see it) it may not be outa line. Helps to know what state or city your in.I'd also like to know if the drivers side would be refurbished or included.
Old Oct 30, 2007 | 02:12 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Considering what all needs to be done as far as removal, clean up, prep. It's in the ballpark. Pulling heads is not a fun chore on a L98 or LT1 car. If you have the tools and the space, do it yourself.
Old Oct 30, 2007 | 02:56 PM
Chatman's Avatar
Chatman
What do you mean by spitting coolant? Could you see it coming out? If it really is a cracked head, ask what they plan to replace it with? With a new head and the markup you would pay, the price doesn't sound that bad to me.
Old Oct 30, 2007 | 07:15 PM
hexane's Avatar
hexane
Time for a nice heads/cam combo! I would DIY as there are a lot of shops in general that rip off us Corvette owners. Its just a small block Chevy with an EFI intake. No more, no less. Just a wiring harness and a few more things...
Old Oct 30, 2007 | 07:39 PM
corvette1989bham's Avatar
corvette1989bham
if you havent done it before you can break a lot of things and costing you more money...the price sounds reasonable.
Old Oct 30, 2007 | 08:03 PM
dan0617's Avatar
dan0617
I would really highly doubt you have a cracked or broken cylinder head. If it is a head gasket, then I would think about $800. My brother's firebird got new head gaskets by a local mechanic, it was $650 for labor and gaskets and all.
Old Oct 30, 2007 | 11:50 PM
motorholmes's Avatar
motorholmes
Old Oct 31, 2007 | 01:01 AM
neat's Avatar
neat
Where are you located? If you're nearby I'll check out the head for you.
It sounds kinda odd that a head would crack and externally leak coolant, but it is possible.
I don't think $1300 is out of line, but only if that includes most/all the parts. If that's just labor, that puts them at over $100 and hour, and that's just a tad high for labor rate. Our shop charges $70 an hour for labor, and there's a shade tree guy up the road who only charges $40.
Old Oct 31, 2007 | 07:34 AM
Brimis's Avatar
Brimis
That's a $118.00 oer hour. Time to go shopping.
Old Oct 31, 2007 | 01:28 PM
Jeffvette's Avatar
Jeffvette
Forgetting parts/oil/coolant?
Old Oct 31, 2007 | 07:32 PM
Sam Lam's Avatar
Sam Lam
Did this problem suddely happen? Was there evidence of a leak in the last few weeks?
My advice is going to be different from the other posts!
1. Get another opinion on the problem from another competant mechanic.
2. Examine the water connections (2) on the throttle body coolant lines. A leak in this area will run toward the back of the engine and appear to coming from this area.
3. Make sure the intake bolts are tight. I have found coolant leaks on SBC engines and the intake bolts were loose. Guess how I fixed the problem
4. It is not normal for a head to suddenly crack and this is probably not your problem.
Do some more leg work before you get out the folding $$$
To Major Repair?
