guys just did the lt1 intake swap. what kind of fuel pressure should i run car is a 90 l98 with 24# ford injs. 1.6 rr 52mm tb what would be a good base timing mark 6 is stock i thought about 8 hope someone can give me a little help geo.
87 just about got her done i put the dist. in wrong so i had to wait for a friend to get in where it should be, waiting on fittings for coolant lines then i can get fuel pres. reg. plumbed in and that should do it will post pics of lines and other things soon. as i said in earlier post if you can go with small cap distb./remote coil do it you then can use 1/2 pipe thread for coolant lines one thing else if you can find fuel rail with an6 fittings welded in that the way to go any ? dont be afraid to ask or call 814/849/3364, i wore out dock351 with ?s if you can go with air pump delete bracket that a plus also more room geo.
I may shoot you a few emails.
How tough (expensive) do you think it would be to get the 6an fittings welded to the fuel rail? I already have the fuel rail and i know a couple of people at local shops that weld aluminum. I just don't know if they do anything so small.
I actually bought some metal fuel line, a flare tool and a bending tool. I was going to make my own lines to look almost stock.
I was hoping to use my stock distributor because I hear it's better than the small ones but I would imagine like everything else, you get what you pay for. If it doesn't fit, so be it but I'm going to try my best to make it work to save a few bucks.
Where did you mount your remote t-stat housing? Did you install steam lines in the front of the intake?
Crap, I'm hijacking your thread. PM me the answers if you don't want to fill your thread with non related stuff.
You will likely hear from me either by email or phone once I tear into it.
Thanks again.
thanks kool that is about what is done to my car will try 42# and work from there here are some more pics of lti intake swap view of coolant line routinghousing mounted frt of alt. bracket for housing an 10/1/2 pipe in intake fitting waiting on more fittings to finish coolant lines ps sorry about the way the words are mixed up but you guys get the drift
