new emblems after paint shop
Old Nov 17, 2001 | 05:34 PM
rxbdwl's Avatar
rxbdwl
Default new emblems after paint shop
Well I've decided on my paint guy and it's going to the shop in a couple of weeks. Today I removed the hood, gas door and rear bumper emblems. The hood emblem is fine. The other two were stuck down with what appears to have been a gasket that acts like double face tape. Two questions. Is the hood emblem supposed to have this too? It did't. Also, when I order the new rear emblem, will it come with the gasket, and where can I purchase just the gasket for the gas door emblem? Thanks. :confused:
Old Nov 17, 2001 | 06:05 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
Default Re: new emblems after paint shop (rxbdwl)
when i got mine back i ordered the back one from zip, i needed a new corvette one and i used the others they where ok. the corvette one had two sided tape on it the gas and the front hood are screwed on with 2 nut same as the hood.my body shop broke my bolt off the front one they used sum kinda glue on it looks fine and i know it is very hard to get the bolts on it because they are in very deep i couldnt get to mine with my hand. my 2cents hope it helps jay
Old Nov 17, 2001 | 06:16 PM
rxbdwl's Avatar
rxbdwl
Default Re: new emblems after paint shop (jparr)
Yeah, the hood and gas door had nuts on the back but on mine, the gas door also had that double face type gasket like the "corvette" on the back. May have been one of those deals where they change something in mid year. Good to know your gas door emblem had no gasket though. If I can't find one I'll just forget it. I'm guessing the "corvette" will come with the double tape. I have to replace it as it suffered considerably in the removal process.
Thanks for the reply.
Rex
Old Nov 17, 2001 | 09:48 PM
rxbdwl's Avatar
rxbdwl
ttt :D
Old Nov 17, 2001 | 11:14 PM
importeater's Avatar
importeater
just buy new ones off ebay or from the corvette mags..why spend $1000+ on paint & not $50 for a pair of emblems..?
Old Nov 18, 2001 | 12:27 PM
rxbdwl's Avatar
rxbdwl
Default Re: new emblems after paint shop (importeater)
Well, I'm thinking along those lines myself. I still don't know if the double sticky gasket comes with the emblems or not. It comes with the "Corvette" across the back, but I was asking about the gas door emblem.
Rex
Old Nov 18, 2001 | 12:53 PM
Corvette0096's Avatar
Corvette0096
The ones i bought from GM have the stickey tape on them. Just have to remove the protective red film. That is the new style for the 96. I got them off E-bay for like $40 for the pair New in box.
Old Nov 19, 2001 | 12:41 PM
SunCr's Avatar
SunCr
All of the emblems I've bought come with the adhesive, but I recommend you take it off and use the bolts only. Makes detailing much easier: just remove the emblems and you can wax underneath them without leaving any traces of wax.
Old Nov 19, 2001 | 01:13 PM
jwade91's Avatar
jwade91
I replaced mine from The Last Detail. They came with two side foam tape. I think they were only like $16 or so a piece. Actually I left off the nuts. Use a wax like The Wax Shoppe that doesn't dry white if you are worried about that sort of thing. Works for me.
To new emblems after paint shop
