87 parking brakes
Old Nov 2, 2007 | 09:06 PM
ls1dave's Avatar
ls1dave
Default 87 parking brakes
Does anyone have a diagram of the parking brake cable routing??
Old Nov 2, 2007 | 09:34 PM
airblaine's Avatar
airblaine
Default out of my FSM,
this is the only one i could find, the main cable runs along the driver side frame rail and has a pronounced bend in front of the rear wheel.
Old Nov 3, 2007 | 10:01 AM
ls1dave's Avatar
ls1dave
Thank You!!! That is what I needed.
Old Nov 3, 2007 | 10:12 AM
c4cruiser's Avatar
c4cruiser
That diagram is for the 88 and later cars. The 84-87 cars use an internal drum parking brake. While the main cable does run down the driver's side as shown, the individual cables were routed slightly differently with the cable ends going into the backing plates. The individual cable housings pass through a hole in the bracket that holds the dog bones to the frame.
Old Nov 3, 2007 | 01:55 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/Parki...Adjustment.pdf
http://members.shaw.ca/agent86/Parki...20Assembly.pdf
Old Nov 3, 2007 | 08:05 PM
ls1dave's Avatar
ls1dave
c4cruiser and agent86.....thank you. When I bought the car the previous owner obviously had parking brake issues. He had removed all the cables and the parking brake shoes and hardware. I bought new cables and connectors but did not know the correct routing.
Thanks for the help guys,
Dave Calvert.
To 87 parking brakes
