Automatic headlights - bypass!
Old Nov 18, 2001 | 07:57 AM
Sliding's Avatar
Sliding
Default Automatic headlights - bypass!
My vette is for canadian market and it have automatic headlights.
I would like to bypass this but i'm not sure where is sensor location.
If anybody have done this before please give me some info.
Thanks!
:chevy
Old Nov 19, 2001 | 02:09 PM
Sliding's Avatar
Sliding
Default Re: Automatic headlights - bypass! (Sliding)
Nobody?! :rolleyes:
Old Nov 19, 2001 | 11:55 PM
A's Avatar
A
Automatic headlights :confused:
Why, whatever do you mean??
In my previous experience, manual headlights on a Vette = broken :D
[edit] wait, doesn't KaleCo make a kit like this? :jester
[Modified by A, 9:58 PM 11/19/2001]
Old Nov 21, 2001 | 12:57 AM
ZARDOZ's Avatar
ZARDOZ
Cruising
From a fellow Canuck with the same question, and no answer. I posted a similar question over a year ago and did not get one reply. I guess the "twilite sentinal" is not an option in the States. I have even inquired at the local Chevy dealer and they don't know how to bypass it. The photocell in the dash actually creates a micro voltage when light is applied, so shorting it out doesn't work. Hope you have better luck than I have had.
Old Nov 21, 2001 | 11:03 AM
A's Avatar
A
Default Re: Automatic headlights - bypass! (ZARDOZ)
Ok... but what is it? What on earth are you guys talking about? :confused:
From what you just said, I'm guessing that the photoreceptor senses that there's not much light and automatically deploys the headlights. Am I close? If that's the case, then I've never heard of such a thing :nonod:
Old Nov 21, 2001 | 12:19 PM
scorp508's Avatar
scorp508
Default Re: Automatic headlights - bypass! (A)
The Canadian export cars have a twilight sentinel that automatically rotates and turns on the headligts. :(
Old Nov 21, 2001 | 03:08 PM
John Row's Avatar
John Row
From reading the 94 Service Manual, it appears that the sensor is in front of the driver on top of the dash board. If there is anything there that would be it. There's nothing in that location on US cars.
Hope this helps,
Old Nov 21, 2001 | 07:39 PM
Shawn93PoloConv's Avatar
Shawn93PoloConv
Default Re: Automatic headlights - bypass! (John Row)
Since the late 80's, all Canadian cars were required to have daytime driving lights, like the C5's have now. When you have the car in gear, the lights go on and you can't turn them off. Real pain at drive-ins but they were intended to reduce head-on collisions that occur more frequently on 2-lane roads for the longer dawn/dusk periods. The cars would be easier to see.
Old Nov 24, 2001 | 01:22 PM
Sliding's Avatar
Sliding
This is actually called Daytime running lamps ( RPO T61 ).
Looks like it's not an option for USA.
It works like this:
As soon as you turn the ignition key headlights automatically opens.
That is if the car is in garage or in dark place.
If the car is at sunlight headlights will stay closed.
But the thing is when they opens you can't close them at your own will.
Sometimes it is annoying but the main problem is that it makes car slower and we don't want that, do we!?
I'll have to work something out.
Thanks anyway.
To Automatic headlights - bypass!
