Window is stuck in down position
Old Nov 4, 2007 | 04:03 PM
noneplease's Avatar
noneplease
7th Gear
Default Window is stuck in down position
Hello,
Does anyone know a way to raise the driver door window up manually? My window motor died with the window in the down position in my 94. Tried tapping on the motor, got nothing, it's dead. I am stuck with the bolt that holds the window behind the motor assembly. It looks like the window just needs to be raised a few inches above the motor so there it room to take off that last bolt the the window will not budge upwards at all. Any input is greatly appreciated.
Old Nov 5, 2007 | 12:16 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
FSM was no help just said to raise the window to remove the bolt.
Old Nov 5, 2007 | 12:49 AM
MrRenoman's Avatar
MrRenoman
Have you isolated the trouble to the motor?
Have you tried tapping into the harness going to the motor and apply power directly to the motor?
Art
Old Nov 5, 2007 | 01:05 AM
Kinkajou's Avatar
Kinkajou
Try closing the door ( slamming ) while activating the switch, that usually makes the motor work in my 94 Vette.
Problem is that you can not raise the window by hand, the gears in the motor will not allaw you to do that.
To Window is stuck in down position
