blown directional
Old Nov 6, 2007 | 02:04 PM
littleredcorvette88's Avatar
littleredcorvette88
Default blown directional
i have a 91 vette and now the directionals are blowing when the car is put in reverse anybody know how to fix this
Old Nov 6, 2007 | 07:31 PM
badabing9's Avatar
badabing9
what do ya mean the directionals are "blowing??? you mean the fuse?
Old Nov 6, 2007 | 08:13 PM
jfb's Avatar
jfb
You have a short circuit in the back up circuit after the backup switch (if manual xmsn) or after the xmsn gear selector sw ( if automatic). I would first check the wires on the left and right rear cornering lights and the backup lights first. Then trace the wire from the reverse switch and look for worn insulation on the wire shorting to ground somewhere along its length. Make sure that the turn b/u fuse is 15 amps.
Old Nov 6, 2007 | 09:53 PM
badabing9's Avatar
badabing9
he never specified if it was a fuse or not. assuming it is, pop out the fuse that is for the lights in question and substitute a 12v cornering marker light or back up bulb and fasten to the contacts that the fuse would contact.
if the light is bright when applying the brakes, you have a short. if the light remains "dim", there is no short. this is what we used to do when troubleshooting concealed wiring in structures saving a lot of fuses and tripped circuit breakers.
Old Nov 6, 2007 | 10:39 PM
littleredcorvette88
yes it is the fuse that blows when the car is put into reverse and it is auto when it is put in reverse the reverse lights blow and the directionals blow (the fuse)
Old Nov 6, 2007 | 10:59 PM
jfb's Avatar
jfb
You say the reverse lights blow. Do you mean that the backup light bulbs burn out, or do you mean they go out because the fuse blew? I don't see how the lights could possibly burn out since you have a 12v battery and 12v backup lights and no possible wiring fault can apply more than battery voltage across backup light bulbs designed to light up for a long long time with 12v applied.
Old Nov 6, 2007 | 11:00 PM
badabing9's Avatar
badabing9
Old Nov 7, 2007 | 12:36 PM
littleredcorvette88
no the fuse to the directionals and the reverse light blow they are on the same fuse the lights dont blow the fuse keeps on blowing
Old Nov 7, 2007 | 03:23 PM
jfb's Avatar
jfb
Read my first post.
To blown directional
