I've got supercharger in my future plans so I have a few questions.
I'll probably build a new engine (out of my present) for it but here is
what troubles me.
Centrifugal supercharges won't make boost until some rpm's (lets say
2500 and up). If I build engine with low compression, ~8:1, how will
that engine perform on low rpms <2500?
On the other side, would it be better to build engine with similar to
stock compression, ~9.5:1, all forged, and keep max boost under 10psi?
Tuned properly, the 8.1 motor will take much more boost & produce much more HP & tork. HP & tork on a graph are curves, and the higher HP tork motor is going to have more below 2500 RPM all things being equal.
You drive the BEST Amarican performance car made!
Why are you concerned about -2500RPM?
Unless you are building a truck to slow clomb over rocks.....
Actualy it will be more like 3K-3500 befor you start making any real boost.
You mention centrifical blowers with this effect, but you should know that this will be common for roots , and turbos too.
if you are realy concered about boost lag, then i would go for a Nos Kit.
Your car can be just as fast but there is NO lag. It will have "snap your neck response"
With a centrifugal blower like a Vortech or Paxton, I like a compression ratio of aroud 9.5:1, so it's snappy when you are just cruising around. Then use a good intercooler and keep the boost at 10-12 or below and you should have a great combo. An intercooled 7.4psi of boost makes it perform like the motor grew by 50% at higher rpm. From 4 grand to wherever your redline lets you go, it just pulls hard. Great with a stroker so you are pretty strong down low too.
Nitrous I would go with 10:1 on the street with aluminum heads.
We build our ATI ProCharger bound engines at a 9.5/1 compression ratio, no matter how much boost we are shooting for. Check out this Corvette that is making 740 rwhp and still gets 28 mpg and you can still takes vacations with it. http://www.exoticperformanceplus.com...Car.php?car=40 Bob
