How to tell
Old Nov 19, 2001 | 01:11 PM
C4@your_door's Avatar
C4@your_door
Default How to tell
if you have a bad or bent frame?
Old Nov 19, 2001 | 01:27 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: How to tell (C4@your_door)
If it's realy off someone behind you may be able to see it. Otherwise a good frame shop is the ticket.
Old Nov 19, 2001 | 06:40 PM
bogus's Avatar
bogus
check tire wear...
Old Nov 20, 2001 | 11:43 AM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Take measurement diagonally from from the center of the lower ball joint on the front suspension to the center of the rear suspension where the strut bolts.
Old Nov 20, 2001 | 12:55 PM
Dave's_88's Avatar
Dave's_88
Default Re: How to tell (Mez)
Do all of your tires touch the ground? If not....you might have a bent frame.
To How to tell
