Has anyone tryed these heads before?
Old Nov 11, 2007 | 01:18 AM
thetoy's Avatar
thetoy
Default Has anyone tryed these heads before?
http://www.araoengineering.com/pakag...age%202%20Port Just looking around at some heads and these things seem to have some pretty good flow numbers. I was wondering if anyone here has ran these before in a corvette? And if so, are there any intakes out there that would flow enough and fit under a stock hood.
Old Nov 11, 2007 | 01:36 AM
cv67's Avatar
cv67
St. Jude Donor '05
Watch their shop car make passes down my street all the time
THey are a large piece, doubt anything as far as factory accessories/brackets would fit on them. Interesting piece though.
Old Nov 11, 2007 | 02:32 AM
5abivt's Avatar
5abivt
There was an f-body that used the dominion 32valve heads on an LTx motor before. I didnt read the link much but it appears it's a similar idea. The camaro made 650+ hp on the motor alone.
Old Nov 11, 2007 | 07:54 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
If you are going to go that exotic you might as well put a set of 15* heads on and make abot 800hp
Old Nov 11, 2007 | 10:13 AM
comp's Avatar
comp
Old Nov 11, 2007 | 12:07 PM
Demonic85's Avatar
Demonic85
How can you have 32 valves on a car that uses a 16 valve camshaft?
Old Nov 12, 2007 | 08:13 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
2 rockers mounted together, on a shaft. Each push rod opens 2 valves=32 valve head using a 16 lobe cam.
Seems simple now, doesn't it.
Old Nov 12, 2007 | 08:27 AM
JackDidley's Avatar
JackDidley
I had a Honda CX 500 motorcycle back in the 80s that operated the same way.
Old Nov 12, 2007 | 08:29 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Can that be accurate?
Old Nov 12, 2007 | 09:59 AM
AssocRacer's Avatar
AssocRacer
Why not? I can see one pushrod opening two valves. Hell, it would be as simple as having the pushrod in the middle of the rockers pushing up on a plate that would be connected to both rockers. If the metal used to connect the rockers was the right kind of metal and held it's properties, each valve would open the same amount every time. However, after visiting the website, i can think of alot cheaper ways to get the kind of horsepower you may be looking for. 5 grand for a set of heads? That's kinda stiff......
Old Nov 12, 2007 | 10:01 AM
cv67's Avatar
cv67
St. Jude Donor '05
With those heads you dont need much cam at all to make a lot of power.
Old Nov 12, 2007 | 10:12 AM
red L98's Avatar
red L98
Old Nov 12, 2007 | 10:27 AM
rick lambert's Avatar
rick lambert
and it almost always comes down to big HP =$$$$$$$$ for heads and induction. Cam and exhaust is minor $.
Old Nov 12, 2007 | 10:31 AM
Mojave's Avatar
Mojave
There has been a lot of talk about these over on LS1Tech. AFAIK, only one, maybe two, cars have these on and are actually running. Tons and tons of fabrication work is required. I would personally go with SB2.2 stuff long before I tried these.
Old Nov 12, 2007 | 11:24 AM
aboatguy's Avatar
aboatguy
Old Nov 12, 2007 | 11:32 AM
Demonic85's Avatar
Demonic85
Yeah I guess that makes sense, I think i've seen a similar setup on a B&S lawnmower engine Its cool that you can do that, but it seems like too much money to me.
Old Nov 12, 2007 | 11:54 AM
Muffin's Avatar
Muffin
Why not go forced induction?
To Has anyone tryed these heads before?
