96 vette hood prop stuck?
Old Nov 11, 2007 | 02:30 AM
86GoldProject's Avatar
86GoldProject
Default 96 vette hood prop stuck?
A while back I got a hood prop for a 96 vette to use on my 86, when I got it I checked to see if it worked properly by pushing the strut down and letting it return on it's own, thats the last time I checked it. After installing it on my car it's now stuck fully extended.. no matter how hard I push down on it I can't get it to budge.. any ideas?
Old Nov 11, 2007 | 08:28 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You do realize that you have to push the cover tube to the side, when closing hood, right ??
Just checking
Old Nov 11, 2007 | 09:00 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Just checking
They do lock in the up position
Old Nov 11, 2007 | 10:34 AM
86GoldProject
yeah, it's extended about 1/4th of an inch above where it would rest on the tube, hood isnt on yet, prop is just bolted to the car.. like I said it worked when i first got it and tested it, but after I took the time to bolt it to the car it won't go back down..
Old Nov 11, 2007 | 02:34 PM
the blur's Avatar
the blur
There is no way you can compress those by hand. You need the weight of the hood to compress the high pressure gas charge in there.
Old Nov 12, 2007 | 01:49 PM
rickwhoo's Avatar
rickwhoo
try disconnecting it and rotate the shaft counter clockwise and try again.
Old Nov 13, 2007 | 02:32 PM
86GoldProject
weird, when I first got it I could compress it by putting 1 end on the ground and putting all my weight on it..
Old Nov 13, 2007 | 02:39 PM
the blur's Avatar
the blur
If I did a hand stand on the hood prop, it would compress too.
To 96 vette hood prop stuck?
