vortex cold air intake question
Old Nov 11, 2007 | 05:54 PM
badabing9's Avatar
badabing9
Default vortex cold air intake question
i have an opportunity to pick up a vortex cold air intake for +/-$125.00 and need some opinions.
1) is it worth the money (it lists for $300.00+/- but not what i mean) in the effort it takes to install? i read somewhere that it involves the cutting of the radiator shroud..
2) the air filter for it lists +/=$49.00 .
3) is there another round type filter that could take it's place inexpensively?
4) anyone actually using one?
thanks.
Old Nov 11, 2007 | 06:17 PM
excessive81's Avatar
excessive81
yeah you have to cut the rad shroud to install it. it a pretty good kit....true cold air. if you not going to buy it would you give me the info so i can get it for my race car. i has no air box in it at all just a k&n attached to throttle body lol
Old Nov 11, 2007 | 06:21 PM
badabing9's Avatar
badabing9
thanks for the reply. so, you are not currently using one or have used one in the past sir? was curious as to how much cutting was involved and NOTICABLE performance gain(s).
Old Nov 11, 2007 | 07:45 PM
Nzzz's Avatar
Nzzz
There is no "noticable" gains on the car. Comments have rose about the air box warping.
Old Nov 11, 2007 | 07:47 PM
badabing9's Avatar
badabing9
ecklers advertises 20-22hp gain but then again, they are selling them.
Old Nov 11, 2007 | 09:03 PM
vader86's Avatar
vader86
It doesnt give the hp advertised, but it sounds good.
If you want to blow some money, go for it.
Old Nov 11, 2007 | 09:11 PM
badabing9's Avatar
badabing9
i may just toy with it for a while.
as taken from the ecklers site;
Corvette Cold Air System, With Clear Cover, BPP Vortex Rammer, 1985-1989
* Up to 22hp Increase
* 5mph & 3.5 Tenths in ¼ Mile
* Replaces Stock Air Box
The Vortex Rammer obtains cool, pressurized air from the radiator cavity, drives it through the radiator shroud into the specialty designed scoop and forces it into the Rammer sealed box. On C4's it is then routed into a revolutionary air cleaner that contains an internal velocity stack. The radiator shroud requires a simple cut-out on all installations. Available with a black or clear scoop that houses the filter. Installation hardware and instructions included.
Old Nov 12, 2007 | 02:02 PM
excessive81
i had one on my c6. i have put them on several customers with c4's cars as it the only true cold air kit for a c4. they good for 3 tenths on the c5 c6. i have no track data on the c4's though. the hole you have to cut is the size of a piece of paper...or a lil bit smaller. does get real cold air from outside the engine compartment.....won't get 22 hp form it that i can tell yu 100% for sure
Old Nov 12, 2007 | 02:33 PM
staugur's Avatar
staugur
If you add up all the HP gains on ecklers site you can end up with a 500HP vette for just over a grand.I didn't realize this when I built my puny 435 HP stroker for around $8000.
Old Nov 12, 2007 | 02:38 PM
vader86's Avatar
vader86
Dont ever believe any power claim in Ecklers, its false advertising.
Old Nov 12, 2007 | 06:28 PM
badabing9's Avatar
badabing9
for the most part, i don't believe most of what i read unless i can verify it, especially from advertisers.
badabing9's Avatar
badabing9
for the most part, i don't believe most of what i read unless i can verify it, especially from advertisers. i take it all with a grain of salt for sure!
Old Nov 12, 2007 | 06:29 PM
badabing9's Avatar
badabing9
i NEVER said that i believed them, i just posted a description as to what was on their site.
Old Nov 12, 2007 | 07:06 PM
pipe's Avatar
pipe
Lot's of guy's have em on and alot complain about the airbox either warping from the heat or cracking. I guess i'm lucky mine never cracked or warped. It's a really good idea gettin the cold air in but just made cheaply. I should have made a test at the strip before I installed it and after. It's a good practice to keep that cone filter clean and re oiled often. I still have mine on and no problems. Pipe
Old Nov 12, 2007 | 07:16 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
It's a POS. Stock airbox with a clean filter and cut lid works just as well.
Old Nov 12, 2007 | 07:28 PM
badabing9's Avatar
badabing9
a-ok......i think i have all the info i need...thanks.
Old Nov 12, 2007 | 08:31 PM
excessive81
ecklers is like me or any other vender.... just using the info given to them as a description of the product. if you call me you won't hear 22 hp coming out of my lips, lots of time we are restricted on price and descrition of the products that we put on our sites
To vortex cold air intake question
Old Nov 12, 2007 | 09:15 PM
badabing9's Avatar
badabing9
well, like any vendor here or anywhere else, i usually don't believe a word they say unless the item is tested by independent entities as well as actual users not affiliated in any way with the marketing,distribution or advertising of the item. think i have all the info i need...thanks.
Old Nov 13, 2007 | 03:39 PM
excessive81
not saying you can not believe what they say by any means. some places just sell parts so they just repeat what the manu says. we sell and install them so we have a lot more idea what the parts will do. as for the breathless box...i said if you don't want it i do...that should tell you something!!
Old Nov 13, 2007 | 04:05 PM
Red Sleeper's Avatar
Red Sleeper
I currently have a cold air intake on my '92. Its been on there for several years.
When I first got it I attached a pressure Gage where the air temperature sensor was. I wanted to see if I could get any ram-air affect (boost). To make a long story short at 90 mph with no air filter and at WOT I started detecting a slight pressure of about 10" of water.
I think but I may be wrong about 28" of water column is equal to 1 psi.
If 1 psi is equal to about 10HP then 10" of water is equal to about 3HP and that is at 90mph. The HP increase from cooler air can be added to the ram air affect and you might get a whole 5 HP???
The cold air intake probably helps a little but not much bang for the bucks!
