How to remove front parking light
Old Nov 12, 2007 | 06:09 PM
dknee928's Avatar
dknee928
Cruising
Default How to remove front parking light
I want to change out the front parking/fog light lense 1995 model. There seems to be two 10mm bolts in an area under the bumper access flap but no way to get at them. Any ideas from those who have done this? thanks in advance
Old Nov 12, 2007 | 06:55 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Those access flaps are for changing the bulb.
From what I've read here, to actually change the whole housing will require you to remove the front bumper.
Old Nov 12, 2007 | 09:33 PM
c4cruiser's Avatar
c4cruiser
The front bumper cover does have to come off. Lots of small screws and nuts.
The park/fog lamp units are a sealed assembly. The lenses are glued to the shell. I don't think you can even buy separate lenses.
Old Nov 12, 2007 | 10:26 PM
dknee928's Avatar
dknee928
Cruising
Default yikes
not what I wanted to hear but thanks, anyone here removed the bumper before? any hidden screws to look for thanks
Old Nov 12, 2007 | 10:30 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I don't know if they are similar but I just replaced both of mine in my '85, it takes less than an hour to remove the nose. No hidden bolts but get some masking tape and put it on the edge of the nose where it meets the hood and put a couple of strips all the way across the hood. This will keep the paint safe from nicks or scratches from the wrench.
Old Nov 12, 2007 | 11:06 PM
jakers's Avatar
jakers
St. Jude Donor '06
Yes, you can buy the lenses seperate! In fact, I have a set in the garage that will go on my car soon. I just need to figure out what type of glue to use...
To How to remove front parking light
