Change Oil Light?
Old Nov 12, 2007 | 11:11 PM
-WhItE_NoIsE-'s Avatar
-WhItE_NoIsE-
Default Change Oil Light?
How do you rest set the change oil light on a 93 Vette?
Old Nov 12, 2007 | 11:38 PM
jsavoy's Avatar
jsavoy
Originally Posted by ruby9246
1 - Turn key to RUN, but don't start engine
2 - Press ENG MET on the trip monitor. Then within 5 seconds, press it again.
3 - Within 5 seconds press and hold GAUGES on the trip monitor. The CHANGE OIL light should start to flash.
4 - Hold the GAUGES button till the CHANGE OIL light stops flashing and goes out. This should take about 10 seconds.
When the light goes out the monitor is reset. If the monitor doesn't reset, turn the ignition off, then try again.
http://forums.corvetteforum.com/show....php?t=1861334
