mid 12 sec car
Nov 14, 2007 | 03:38 PM
mid 12 sec car
96 vert, a4, 307 gears, K&N, cut lid, muffler elim. what would be the cheapest/easiest way to get a mid 12 sec car
Nov 14, 2007 | 04:50 PM
Nov 14, 2007 | 06:04 PM
Quote:
Originally Posted by
rickreeves1
Nos...
Nov 14, 2007 | 06:09 PM
Nzzz
Forced Induction or NOS. The L-98 runs out of breath due to it's design so the time you get to the end of the 1/4, you have lost most your power.
It's a 96, it should be an LT1.
I agree with nitrous, put a bottle on it and call it a day.
Nov 14, 2007 | 06:31 PM
if you want the power all the time i would say a converter,and ported heads/cam should get you well into the 12's with some drag radials.
Nov 14, 2007 | 08:36 PM
Nitrous is cheapest followed by a torque converter. I'll say 3000 or 3500 stall without the juice will get you there.
Nov 14, 2007 | 09:39 PM
dont want to do nos and also it gots to be drivable because it my daily driver.
Nov 14, 2007 | 10:05 PM
Long tube headers, exhaust, dyno tune it and you should be well on your way. A converter would really help too.
Nov 14, 2007 | 10:51 PM
corvette8189
Some 1.6 roller rockers, headers, dyno tune, and drag radials might put you pretty close if it's a strong car.
Nov 15, 2007 | 10:27 AM
3.73 gears and a 2800 stall converter should achieve mid 12's on that car. Since it's a daily driver maybe a 2200 stall. Spray it and achieve mid to low 11's. Car maintains stock driveability until you hit the nos.
corvette8189
+ no N2O.
What do you mean by cheap and easy?
Nov 15, 2007 | 11:47 AM
whats the most bang for the buck besides nos
Nov 15, 2007 | 03:01 PM
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Nov 15, 2007 | 05:03 PM
3000rpm Stall Converter (TCI StreetFighter is nice)
3.73:1 Rear End Gears
Long Tube Headers
+ Dyno Tune
That right there will get you damn close to mid 12's on an LT1 corvette.
Nov 15, 2007 | 08:05 PM
And drag radials, don't forget the drag radials.
Nov 15, 2007 | 08:45 PM
1988 coupe, zz4 w/ tuned port, TCI 700, w/ 3500 stall, long tube headers,
drag radials, 24' front runners, line lock, 2:73 gears, vehicle weight 2950 =
1.662 60', 12.309 et, 109.99 mph (w/ my wife driving) adj alt. 500'+/- , no wind, @ New England Dragway.
Nov 15, 2007 | 10:07 PM
corvette8189
I can lead by example. I turned my 92 A4 LT1 into a mid-12 second car, and it's still my well-mannered daily driver.
See sig for complete list of mods. Basically, the 4 most important mods were:
1. HotCam kit with 1.6 RR's
2 LT headers and low-backpressure exhaust system
3. Gears. Now I'm running a Dana44 with a 3.33 gear ratio
4. Torque Convertor. I'm running a Precision 2600 stall TC
You need good traction to get to mid 12's. I routinely run 1.69 to 1.72 60-foot times, so I need good drag radials and a line lock so I can heat 'em up. Electric water pump also helps, along with a fan switch.
