need cam help
Old Nov 14, 2007 | 09:16 PM
justmitoy's Avatar
justmitoy
Default need cam help
i have an lt1 with stock valve springs and 1.6 roller rockers
can i use a cam with .510/.510 lift or a 503/510 lift without changing the valve springs if not what is the "biggest" cam i can use with stock springs and 1.6 roller rockers? please pm me with your advise thanks
Old Nov 14, 2007 | 09:19 PM
clf93lt1's Avatar
clf93lt1
You are pushing them with just the 1.6 rockers.
Old Nov 14, 2007 | 09:26 PM
STL94LT1's Avatar
STL94LT1
You're already running the biggest cam you can run with stock valve springs.
To need cam help
