need help bad
For a no start issue verify the basics first, (spark to plugs, fuel pressure, compression) verify that you installed the distributor correctly, early ones can be forced on if you pulled it down with the bolts, good luck.
By | 2026-06-03 10:34:17
By | 2026-06-03 10:21:50
By | 2026-06-03 15:43:40
By | 2026-05-28 09:31:39
By | 2026-05-27 17:20:09
By | 2026-05-27 16:54:53
By | 2026-04-03 00:00:00
By | 2026-05-20 07:23:03
By | 2026-05-12 16:54:12
By | 2026-05-11 09:50:51
