Help with Antenna
Old Nov 16, 2007 | 10:31 PM
vettemiker's Avatar
vettemiker
Default Help with Antenna
I have a 93 and antenna doesnt go down all the way,stops with 6-8 inches left.What do I need to do to fix it.Is the access from the rear inner panel? Any help appreciated.
Old Nov 17, 2007 | 12:55 AM
Sam Lam's Avatar
Sam Lam
Your antenna is raised and lowered by a small motor located above your left rear tire. The inside of the antenna has a plastic ribbon which has gear teeth on it. Your ribbon is broken and you are going to need a new mast assembly. Get this from a GM dealer or MAD. This is the easy part! Now, you should remove the motor assembly and retrieve the broken ribbon. You reinstall the motor and feed the ribbon into the motor and you are set. Do a search on the forum as there have been many posts on removing the motor assembly. I have a FSM for my 89 model and can fax the procedure to you if you cannot find it in a forum search. BTW, the first time you do this procedure, it will take you 4-5 hours, a lot of four letter words and at least three Bud Lites.
