The engine in my 1996 LT4 Corvette is over heating in the range of 235 degrees to 240 degrees F. Two mechanics have told me they doubt that it's the thermostat. On suggested the Dex coolent used in these cars has a tendency to clog and obstruct the coolent flow and another told me he thinks there may be an air pocket in the cooling system. I had the engine burped and it still over heats. Any ideas what could be causing this? Could it be as easy as just installing a new thermostat? Has anyone had a similar problem? What is normal engine temp?
Normal temp. at idle is in the 228-235 range. This is because the cooling fans are not running until approx. 228 (unless you have the a/c on).
I don't believe the Dex coolent by itself causes clogs. Millions of cars have it in their system. But what WILL cause problems is mixing the Dex Cool with the old green stuff. They do not mix well, and will cause the clogs.
An air pocket is also possible, but you said you had it burped.
Next up, I would check for an airflow blockage. Crawl under the front nose, and look up into the airflow inlet to the radiator. These cars will suck up every type of trash, leaves, etc. there is.
It has to be burbed at op temp with t/stat open to get all the air out, hope it was done right. Turn on AC and see if fans are coming on and like Rolla said check for radiator blockage.
The deal with dexcool is if the system gets low, and air get in the system, it tends to solidify and get crusty, but it usually flushes out quite easily, have you had the cooling system pressure tested? including the radiator cap? if the system is leaking pressure the coolant will boil before it reaches coolant fan operating temp, any older car can have a suspect thermostat, but cooling system problems tend to be a real hands on diagnosis and very diifficult to talk someone through.
I have two GM autos with over 100K miles, both using Dexcool. No problems at all.
My '96 Vette also has Dexcool in it, with around 80K miles. Again, no issues.
It's all in the maintenance.
A lot of the problems you hear about would have happened no matter what coolant the owner was using, just because they didn't do the proper maintenance on the car.
Are your fans coming on @ the overheat temp? If not run the A/C and see if it still overheats.
Like stated first check for radiator obstructions , but after all that I would go to the thermostat next. Just because someone says they doubt it is bad doesn't mean it isn't.
I've been using DexCool for over four years and over 70000 miles without a problem and yes, I had a stuck thermostat. Changed to a new one over a year ago and we run quite cool.
Its really great that your mechanics have such powers and abilities to just look at the engine and eliminate the thermostat, not to be sarcastic.
Take a quick look just to make sure there are no airflow restrictions.
When you turn on you’re A/C, on both fans should be running in low speed. With the outside temperatures this time a year you should not even get to the 215* mark. As long as the fans are running, that’s check #1. Under 70* I don’t even need fans to keep it under 200*.
A partially closed stat will cause that problem. The temperature will just keep climbing slowly depending on the health of the stat. Step #2 is the change the stat, cheep and easy before you escalate your repair process. And I know you will flush and add new coolant.
Do the basics before you go for the radiators and head gaskets.
I use dexcool in my chev 01 truck, I change it and no problems.
PS: Fill in your profile so we can see where you and the car lives.
