Could anyone tell me what the plug gap is when using the Accel HEI high output coil? I have heard that you use a wider gap than .035 when using this coil, but it was on the car when I got it and I have no instruction sheet.I have a stock 89. Thanks WW
Use the same gap as stock .035. The ACCEL HEI coil really doesn't put out a lot more voltage than the stock GM coil. With a stock motor, you may not even see a lot of improvement with the ACCEL coil.
I installed the Accel HEI coil, plus their HEI D.-Module, in my 86, back in 1990. Also Taylor 8 mm plug wires. Gapped a new set of plugs(NGK, as I recall) to .040" ! Have had no problems since, and continue to gap new plugs at the same .040"
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Voltage is determined by the plug gap and the cylinder pressure, not the distributor contents. Opening up the gap will require a larger voltage to jump the gap. This will shorten the spark duration. (The NO Free Lunch rule.) If you truly have an upgraded ignition system (meaning more energy, not voltage, contained in the coil) then this will allow you to increase the gap size (generally a good thing) while not necessarily shortening the spark duration.
the emissions sticker on most cars should give the plug gap. I gap mine with a pertronix flamethrower coil at .045. I am using splitfire triple platinum plugs, and pull them every 10,000 miles, and they just seem to be happy in there. nice n clean
With the same ignition system, the spec for my plug gap is .045". I believe in some older stock HEI equipped GM cars the spec was .060". There is a lot of room for experimentation in plug gaps, especially with the relatively powerful HEI ignition system. When you start to experience misfires, stop increasing the gap and back off to where it didn't.
RACE ON!!!
Clarification: The same ignition system, minus the unnecessary Accel coil. In other words a stock HEI.
Reason: Clarification
With the only advantage of a platinum plug being it's extended life, why do you waste the money on an expensive, premium, 100,000 mile plug that you check on every 10,000 miles?
I agree with the platinum plugs, my son brought them to shop for me and I turned him rright around and sent him back for a regular set of AC,s for 1/4 the money.
From: I live at www.domesticlugnuts.com I sleep in PA
RACE ON!!!
Since I change my plugs every 10k, I just use the Autolite copper plugs. I didn't see any performance or mpg difference with the platinum plugs.
if you want to get the full benefit of the plug and add a few extra hp gap at .047 to .050 and index the plug with the open face towards the exhaust valve. draw a line on the sharpie to know you are opening the face to the exhaust valve.
RACE ON!!!
I would think that he checks, cleans and re-installs them again.
The same as he could do with a $1.00 plug. So if the cheap plugs need to be finally replaced on the third or fourth R&R instead of the eighth or ninth, the cost of the plugs is still less and the labor is the same. There isn't a nickles worth more performance in a platinum plug, just longer life. Platinum plugs are good for the OEs with their emissions warranties, and the guys that need the manual to find the hood latch, and are paying the labor to change the plugs. They are good for the "Nothing but the best for my baby" crowd, but not for tinkerers that know what they're doing.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
My tuner actually recommends a .030" gap for my modified LT1. I compromise somewhere between his recommendation and factory spec, I run them at .035". I have a hotter coil than stock and MSD 8.5mm wires but ignition is stock beyond that. I change plugs at 10K miles and they still always look great. Power and overall efficiency are as much as one could expect for my combination. CR in this engine is 11:1 and in my previous combo was 11.3:1. I've tried both indexing and cutting back the electrodes but found both to be not worth the bother for a primarily street car. I've used NGKs and now use standard Autolite replacements, both per the stock replacement part numbers. Both gave excellent service and good life. I've always had problem-free results with Autolites in any type of vehicle or engine over decades of experience.
