Radio antenna problem
Old Nov 22, 2007 | 08:49 AM
TrickyRicky's Avatar
TrickyRicky
5th Gear
Default Radio antenna problem
I have a 1987 coupe and radio antenna stays up. motor keeps running
all the time and will not go down. Wondering if it a relay problem and
if it is where can I find relay. Any ideas would be appreciated.
1st time vet owner
Old Nov 22, 2007 | 08:59 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The nylon mast rod is probably broken. When it breaks, the motor's limit switch's, cant be switched.
Pull the plastic trim at rear of cargo area and you will see the relay beside the hatch latch. Unplug the relay till you repair or replace the antenna.
I bought the repair kit from GM. It was about $20 and contains the nylon rod attached to the finial end of antenna.
To repair it, you need to remove the motor and mast tube. Pull the rear wheel and inner fender to get better access to it.
Here is a little info from my manual http://members.shaw.ca/agent86/Power%20Antenna.pdf
Good luck and welcome aboard
Old Nov 22, 2007 | 07:44 PM
cmontel727's Avatar
cmontel727
100%. I think I am having deja vu on this post
Old Nov 22, 2007 | 09:02 PM
AGENT 86's Avatar
AGENT 86
I laughed earlier today when I realized I already commented on his other thread.
More like a mirror image.
To Radio antenna problem
