ZF-6 conversion
Old Nov 18, 2007 | 05:15 PM
gtslow's Avatar
gtslow
Default ZF-6 conversion
Just finished converting my 88 from auto to manual. Already logged about 100 miles on it and every thing seems to be fine.
Old Nov 18, 2007 | 06:12 PM
bogus's Avatar
bogus
Looks great!
Question... in that pic, what's up with the floors???
Old Nov 18, 2007 | 06:14 PM
gtslow's Avatar
gtslow
The bottom of the car had damage from previous owner. I think he said he ran over a parking block at night.
Old Nov 18, 2007 | 06:18 PM
garychurchill's Avatar
garychurchill
well as you have everything out, you should fill it in. Something like that would bug me.
Old Nov 18, 2007 | 06:21 PM
gtslow's Avatar
gtslow
Dude thats fiberglass. I had nothing out to make it more easy to fiberglass the bottom.
Old Nov 18, 2007 | 06:24 PM
garychurchill
Thats what I was implying, was re-glassing it in. Didn't mean body filler. I find fiberglass a lot easier to work with than anything else, but then again I used to work on nosebowls for planes, and they are most of the time fiberglass.
Old Nov 18, 2007 | 06:28 PM
gtslow's Avatar
gtslow
Ok man cool, but i posted a tread about a 6-speed swap not about the under side of the car. The car needs more work than that, trust me.
Old Nov 18, 2007 | 06:53 PM
gtslow's Avatar
gtslow
SPECIAL THANKS goes out to CentralCoaster for suppling the list. Helped out a bunch.
Old Nov 18, 2007 | 08:57 PM
LD85's Avatar
LD85
Very nice
Old Nov 18, 2007 | 09:07 PM
Curveit's Avatar
Curveit
Nice work...
Old Nov 18, 2007 | 09:50 PM
bogus's Avatar
bogus
dude... just commenting. The floor is structural, to a degree... you went to a lot of work (and it, as I said above, looks GREAT!)... and to not patch up the floor seems odd to me.
BTW, do a search on the floor materials, I don't think it's simple fibreglass... I think it's the same SMC material as the rest of the car, to it will require a special epoxy.
Old Nov 18, 2007 | 10:01 PM
gtslow's Avatar
gtslow
I plan on doing the floor at a little later date. It will be fixed. The car is driven daily, so was kind of in a hurry. I will do plenty of research before attempting it. Thanks.
Old Nov 19, 2007 | 12:53 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Nice job!
Old Nov 19, 2007 | 02:16 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Nice work! I put sound deadening on my whole floor, two on the tunnel, it didn't help with gear rattle. Is that upper boot from the ZF6 parts car, or is that some universal boot?
So tell me more about this busted floor...
Old Nov 19, 2007 | 07:23 AM
856SPEED's Avatar
856SPEED
I did the same modification, although I do not handle the work myself. What flywheel and clutch assembly did you go with? I recently switched to a RAM disc, pressure plate, and new steel insert in the alum. flywheel (original style clutch went out) and now have now have serious clutch chatter in reverse, making reverse nearly impossible unless you don't mind the whole car rattled apart.
Great upgrade
Old Nov 19, 2007 | 01:18 PM
gtslow's Avatar
gtslow
The lower boot is from a 6-speed car.
Old Nov 19, 2007 | 01:21 PM
gtslow's Avatar
gtslow
Great upgrade
I went with a Fidanza alum. flywheel and a EZ stage 3 clutch. I knew going in to this that the transmission would make some noise do to the single mass flywheel but damn. Havent got on it yet to see if clutch will hold. Still trying to break it in.
To ZF-6 conversion
Old Nov 19, 2007 | 09:56 PM
JA94vette's Avatar
JA94vette
Looks great!!! Congrats on a project like that I did my 94 about a year and a half ago and love it. Much more fun. Have you done anything with the rear?? I ran my 2.59 D36 for 5mo and it sucked but I finally got a D44 with 4.09!! Much better. How is the gear rattle in neutral? Mine is much worse than I thought it would be; I just have to keep the clutch depressed..LOL. Great job!!
Old Nov 19, 2007 | 11:01 PM
gtslow's Avatar
gtslow
Yeah transmission noise is kind of bad but not to noticeable over the camshaft LOL. I have 3.73 gears in the D36. I already have the torque arm and driveshaft ready for when i blow it. At that time I will upgrade to D44.
Old Nov 20, 2007 | 09:56 AM
GRX's Avatar
GRX
