Looking for runner gasket tips
Old Nov 19, 2007 | 12:59 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Default Looking for runner gasket tips
I spent an hour tonight scraping away at the old runner gaskets. And, that was just on the intake....
I have to admit the gaskets are fairly impressive with steel mesh sanwiched between 2 sheets of material (composition?). Anyway, the gaskets came off fairly easy.... that is the main bulk of them. But the material that remains is hard as a rock and glued to the intake. (It seems there's little difference between the remaining petrified material and the aluminum under it!)
My best headway was acheived by using a wood chisel and scraping. (A paint scraper is too weak/dull). I also tried a razor blade but that actually looked like it can leave nicks in the alum! 120 grit emory cloth didn't impress me either (though it will be good for final "buff").
I did make fair headway but I'm not looking forward to round 2. Are there any tricks for getting the rest off? Can anything impregnate that stuff and soften it?
Also, when reinstalling would you use a sealer like "the right stuff" or silicone? (I've seen references to the right stuff but never saw it in stores. Any hints on local retailers?)
gp
P.S. If someone ever looks at my old C4 and says "Dang, look at that fossil, I"ll know they're refering to the hardened gaskets!!!
Old Nov 19, 2007 | 01:59 AM
rodj's Avatar
rodj
"Also, when reinstalling would you use a sealer like "the right stuff" or silicone?"
Probably not approved here but I glue one side on ( base and plenum) and saturated the other side with grease.
Never had a vac leak and comes apart easy.Have reused runner gasket 4 or 5 times.
Old Nov 19, 2007 | 02:03 AM
evmlarry's Avatar
evmlarry
I've successfully used acetone to remove tough old gaskets myself.
Old Nov 19, 2007 | 02:10 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Avoid getting this stuff on your skin...
Install the new gaskets dry.
Old Nov 19, 2007 | 09:26 AM
evmlarry's Avatar
evmlarry
That stuff, if I remember correctly, is basically a mix of acetone with something else that I can't remember. A big bottle of acetone is about half the price of that little spray can. You should use rubber gloves with both.
Old Nov 19, 2007 | 10:39 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Razor blades will definitely nick the aluminum, there are abrasive wheels specially made for gasket removal. You put them in your drill and they will remove the gasket residue while only shining the aluminum. Replace the gaskets dry, that's why they come with the little plastic locator plugs. Old gasket goop is probably the reason your having so much trouble getting the surface clean. If you do use the spray gasket remover, use far away from any painted surface, it's the best paint remover I've ever seen.
Old Nov 19, 2007 | 02:43 PM
GREGGPENN's Avatar
GREGGPENN
Why would they recommend "the right stuff" with intakes and nothing with runners?
I did get a could of shallow nics with razor blade before noticing what it did. Probably not an issue but can I use a sealer to be sure?
Old Nov 19, 2007 | 04:33 PM
evmlarry's Avatar
evmlarry
I would honestly think that those gaskets will press in and fill in the imperfections. My runners have a few small imperfections and once they gasket was squeezed by the torque it just filled in where needed, no issues. I don't think I'd worry too much about it personally.
To Looking for runner gasket tips
