What does a "Code 32" feel like.
Old Nov 20, 2001 | 06:11 PM
Thumper's Avatar
Thumper
Cruise-In II Veteran
Default What does a "Code 32" feel like.
Sometimes when I'm driving the car "hesitates" and feels almost like it's not getting enough gas, then when I take my foot off the gas pedal it smooths out. Sometimes the "Check Engine" light comes on and sometimes it doesn't, but it goes out when I come off the gas too. I thought it was a fuel problem so I have already changed the fuel filter and the fuel pump, now I'm thinking it might be a code 32. Does this sound like a "Code 32" to you???
Old Nov 20, 2001 | 06:32 PM
Rick86's Avatar
Rick86
Default Re: What does a "Code 32" feel like. (Thumper)
When my MAF went out it did just that except I got no codes (I also replaced fuel pump and filter before I suspected MAF). Try disconnecting MAF wires, if that fixes the problem then you got a bad MAF
[Modified by Rick86, 4:33 PM 11/20/2001]
Old Nov 20, 2001 | 07:17 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Sort of like warm apple pie.
Actually, read the code - end the suspense!
Old Nov 20, 2001 | 10:35 PM
Ricks1989Roadster's Avatar
Ricks1989Roadster
Hi Thumper, I had the same problem with my 89'. It would suddenly lose power and throw a code (Check Engine light). Tried replacing the MAF and burn-off relays and it still happened. It turned out to be a bad ECM. Sorry for the bad news, but I hope it helps you determine the cause.
I hope I am wrong because it cost me ~$500 to have it replaced.
Let me know how it works out....
Old Nov 21, 2001 | 12:55 AM
davemach's Avatar
davemach
check this site out for info on codes http://home.fuse.net/c4/
Old Nov 21, 2001 | 02:30 PM
Thumper's Avatar
Thumper
Default Re: What does a "Code 32" feel like. (davemach)
Thanks for the replies. I disconected the MAF last night and that made it worse so I'm checking that off the list. I hope it's not the ECM. Great webpage, now since I know how to check the codes I'll do that tonight.
Old Nov 21, 2001 | 03:36 PM
h rocks's Avatar
h rocks
I couldn't feel anything. It will only happen usually during a cruising period of about ten minutes or more with no appreciable throttle change. I have a block off plate on mine, and feel nothing.
To What does a "Code 32" feel like.
