Glue???
Old Nov 20, 2007 | 10:25 AM
jakers's Avatar
jakers
St. Jude Donor '06
Default Glue???
I am preparing to remove my bumpers to begin the paint process. One of the thing that I really need to do is to remove the fog light/turn signal assembly and replace the lens on them (I already have the new lenses on the shelf in the Garage!)
So here is my question... What type of glue do I use to attach the lenses to the body of the light assembly? Anyone know this?
Don't want to buy new assemblies at over $450 for the pair! I can't afford to experiment with the lenses with model air plane glue, if ya know what I mean!
Old Nov 20, 2007 | 05:18 PM
4DSZR1's Avatar
4DSZR1
I took mine apart, cleaned them and used black silicone RTV sealer as the glue. Worked great. I only used black because the original was. Clear would be a good choice too.
Good luck
Rick
Old Nov 20, 2007 | 06:20 PM
Yellow2015's Avatar
Yellow2015
I did my sons headlights on his mustang last year. I used the bath/kitchen clear silicone. It goes on white but dries clear making less of a mess. Just trim off any excess afterwards.
Old Nov 20, 2007 | 07:12 PM
genefree3's Avatar
genefree3
Definatly a silicoln, if you use the kitchen/bath type you can release it with a good commercial heat gun if you ever need to. We use it for installing bathroom mirrors and soap dispensers in restrooms at the theaters we work in. It survives the typical 13/18 yr. old kids beating on them. Usually the ceramic tile gives up before silicoln.
Gene
Old Nov 20, 2007 | 11:08 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default Silicone
Never thought of that... I am guessing that is similar to what GM put them together with? Can I use a heat gun to remove the old lenses?
Old Nov 21, 2007 | 06:24 AM
genefree3's Avatar
genefree3
Couldn't say for sure, but a word of caution with heat gun. If you have a good commercial gun beware of paint, mine will burn it in a heartbeat.
It should at least soften it and be easier to cut apart.
good luck, Gene
Old Nov 21, 2007 | 09:04 AM
redrose's Avatar
redrose
Default silicone --other uses
home ''fish tanks'' use clear silicone to glue the glass walls/floor together, no other restraints...mine had water 4 ft deep in it and held together for over ten years that i had it, still ok AFAIK...prolly will hold parking lights together.
silicone does have acetic acid in it, might etch clear plastic, apply accordingly.
Old Nov 21, 2007 | 10:21 PM
Yellow2015's Avatar
Yellow2015
good luck, Gene
It can also melt the plastic lens itself if you're not careful. Patience and a thin putty knife and you'll be fine.
To Glue???
