Radio antenna problem
Old Nov 20, 2007 | 04:28 PM
TrickyRicky's Avatar
TrickyRicky
5th Gear
Default Radio antenna problem
Hello first time vet owner, 1987 coupe. Radio motor is running
all the time, wondering if it is the relay and if so where can i locate
relay.
Old Nov 20, 2007 | 07:05 PM
cmontel727's Avatar
cmontel727
If you are talking about the relay for the power antenna... it is located under the plastic cover where the rear window latches down. Just remove the trim from both sides then the cover itself. Unplug the relay it will stop the antenna motor. Ask me how i know
The problem is with the power antenna...The plastic ribbon has broken off inside the motor. Get a new mast unit and be done with it.
Hope this helps
Old Nov 20, 2007 | 08:55 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
100 %
http://members.shaw.ca/agent86/Power%20Antenna.pdf
Old Nov 22, 2007 | 09:10 AM
TrickyRicky
5th Gear
Default Radio problem
Thanks for the info
To Radio antenna problem
