Msd 6AL
Old Nov 21, 2001 | 12:33 AM
YellowC4's Avatar
YellowC4
Default Msd 6AL
does any one have the msd 6al installed on his corvette do you feel any deffernce and where do you put it where is the best location for it
Thanks :confused:
Old Nov 21, 2001 | 12:48 AM
AS84's Avatar
AS84
Default Re: Msd 6AL (YellowC4)
Mine idled a little smoother with it. I installed mine mainly for the rev limiter. I bought a wiring harness (8875) from MSD that made installation a snap. I made an aluminum bracket and put mine right below the pass. headlight bucket. If you're ever going to use nitrous, I suggest the digital 6.
Old Nov 21, 2001 | 02:08 AM
importeater's Avatar
importeater
Default Re: Msd 6AL (AS84)
just love my msd i ended up with the 6t & rev box which is basically a 2pc 6al. ended up mounting the box under the drivers headlight on the bumper & the coil off the drivers fender sorta infront of the master cylinder. msd makes a conversion for the hei cap to run a outboard coil like the blaster 2 i have. all in all i'm really happy with it. fires instantly now, & with nos & high rpm use it's a must
Old Nov 21, 2001 | 04:20 AM
BlackRocket's Avatar
BlackRocket
Just installed mine under the Driver's headlight. It fits perfectly across the front of the tire splashgaurd. Used Stainless-Steel bolts to prevent corrosion. Also, you have to lengthen the wiring, so I bought the same gauge, same color automotive wiring and some black plastic corrugated tubing. After carefully splicing the wires, placed them inside the black tubing and attached with black zip-ties. Looks like a professional installation. I also gunked-up the area where the wires exit the box with some clear silicone to help prevent any moisture from ruining the electrics. Best of Luck :D :D :D
Old Nov 21, 2001 | 08:21 AM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default Re: Msd 6AL (BlackRocket)
Had the 6AL on a TPI camaro, and the Rev limit saved me twice. I would have needed it on the Vette last week where I almost over reved due to a shifter problem. As far as performance, the car ran smother and always fired right up after the install, though I can't say if it added any noticable HP, or a tenth to the ET. Having MSD down the street helps to, I had a bad MSD box a long while ago (extra one) fixed for under $20.
Old Nov 21, 2001 | 08:17 PM
SteveElliott's Avatar
SteveElliott
Tests have shown, and I agree, the ignition is only worth about 1 horse if anything. I need it for nitrous. Installed mine behind the drivers seat down where the anti-lock brake computer is. :cheers:
Old Nov 21, 2001 | 08:29 PM
scorp508's Avatar
scorp508
Default Re: Msd 6AL (SteveElliott)
Do you lose anything for having to run the wires so long?
To Msd 6AL
