Clutch Slip After Bleeding
Old Nov 24, 2007 | 03:06 PM
WINGSTAR's Avatar
WINGSTAR
2nd Gear
Default Clutch Slip After Bleeding
85 4+3 was hard to shift into gears, so I bled the slave cylinder. The cars shift problems are solved, but the pedal engages at the very top and I am getting a lot of slippage. I measured the rod travel on the slave and it is about 3/4". What would prevent it from fully releasing the clutch???
