Roller Rocker Help!
Old Nov 27, 2007 | 09:53 PM
Hansel87's Avatar
Hansel87
Cruising
Default Roller Rocker Help!
ALright, so I decided to look into getting Roller Rockers. I have a stock '87 Coupe. Help me out if I am wrong here. I am planning on getting 1.6 ratio;3/8inch stud size;aluminum;full rocker;self aligning. I just want to make sure that if I get these roller rockers then I will need no other modifications to make them work. Thankyou.
Old Nov 27, 2007 | 10:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You will need non self aligning rockers if you plan to use the existing hardware on your heads. Valve seals and fresh springs make the journey worthy.
Old Nov 27, 2007 | 10:26 PM
AGENT 86's Avatar
AGENT 86
Oh, and most likely, you will need to remove the drip tabs from the valve covers and possibly some material from the bolt towers.
Old Nov 27, 2007 | 10:44 PM
chucks88's Avatar
chucks88
A new set of locks and retainers aint gonna hurt ya either.
Old Nov 27, 2007 | 11:35 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
I went with the Comp Cams chrome molly rockers.
Their advertising says they are stronger and lighter than AL.
I don't know, but I figure you can't go wrong with Comp Cams.
To Roller Rocker Help!
