Vortech kit tuning
Old Nov 29, 2007 | 08:16 PM
MassaRusty's Avatar
MassaRusty
Default Vortech kit tuning
I bought a 94 with the base vortech kit. I would like to have it tuned instead of using the fuel management unit that is one it. What all would I need to do or remove for this. There is also a timing adjustment box. Would I want to remove this? I am just trying to get an idea what would be involved in this. Thanks.
Old Nov 30, 2007 | 03:45 PM
yzfr1mike's Avatar
yzfr1mike
Check with PCMFORLESS.COM I had Alvin tune my 92 and had an excellent result. As to parts needed, you will want a 255 lph in tank pump, larger injectors, a fuel pressure and boost pressure gauges. If you stay stock otherwise, 30 # inj will be OK. Its not a good idea to exceed 6 PSI boost on the stock motor.
With a forged component motor, the sky is the limit, basically. It depends on how much you want to spend- - -!
Mike
Old Nov 30, 2007 | 08:40 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
since this is basically what I want to do with my '95
Can I buy the settings from him?
My '95 has a flash chip.
Old Dec 3, 2007 | 04:01 PM
lisoundsvette's Avatar
lisoundsvette
Give Greg From Blowerworks A Call He Just Might Have A File On Your Set Up. He Took Care Of My Tuning Need And More.
Old Dec 3, 2007 | 04:05 PM
lisoundsvette
GIVE GREG FROM BLOWERWORKS A CALL HE JUST MIGHT HAVE A FILE ON YOUR SET UP. HE TOOK CARE OF MY TUNING NEED AND MORE.
To Vortech kit tuning
