4.56 Gears
Old Nov 30, 2007 | 04:23 PM
ernie22golf's Avatar
ernie22golf
Default 4.56 Gears
Anyone out there running 4.56 gears - are there any unusual worries in going this low - I have a 95 6 spd and if I'm going to keep I'm wanting more quickness - it currently has 3.45 stock.
Old Nov 30, 2007 | 04:36 PM
STL94LT1's Avatar
STL94LT1
I'm very pleased with 4.10's in my M6. Haven't heard of a 4.56 gearset for our cars.
Old Dec 1, 2007 | 02:41 PM
Snakecharmer383's Avatar
Snakecharmer383
I have 3.33's now stock. I'm going to go to 3.73's or 4.11's I think 4.56's would be a bit much.
Old Dec 2, 2007 | 07:28 AM
93 ragtop's Avatar
93 ragtop
Just make sure they will work with your carrier. The other problem may be the additional torque you will be putting on the axles, etc.
Old Dec 2, 2007 | 09:46 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
They won't work with your carrier. I believe 3.73 or 3.92 is as high as you can go without a complete change out. Check to be sure.
Old Dec 2, 2007 | 10:08 AM
DVNCI's Avatar
DVNCI
Unless you are planning on running a really tall drag slick, it's too much.
You'll be shifting constantly around town. 4.10's are perfect with the 6 spd.
Old Dec 2, 2007 | 10:20 AM
cv67's Avatar
cv67
St. Jude Donor '05
4.56 is pretty low, you might find you are slower with a real deep gear than with stock, or say 4.11.
Old Dec 2, 2007 | 10:21 AM
Aurora40's Avatar
Aurora40
Plenty of people put 4.10 gears in the D44.
Old Dec 2, 2007 | 10:54 AM
any4xx's Avatar
any4xx
I had a 4.56 set in a Cobra kit. The smallblock was a very high-winding engine, but it was still a nuisance to drive. Even though all my favorite things start with a 4, I'd not have a 4.xx gear set again.
Old Dec 2, 2007 | 01:14 PM
STL94LT1's Avatar
STL94LT1
4.10's are a whole different story in our M6's. With 4.10 in sixth gear, my car is turning 1850 rpms at 70 mph. Two overdrives definately help tame a 4.10 gearset.
Old Dec 2, 2007 | 01:32 PM
BADDUCK's Avatar
BADDUCK
Do you know what a carrier is?
Old Dec 2, 2007 | 01:40 PM
Aurora40's Avatar
Aurora40
LOL, I guess not! :o
Old Dec 2, 2007 | 01:43 PM
STL94LT1's Avatar
STL94LT1
Yes, most if not all including myself are still using the stock 3.45 carrier with our 4.10 gears.
Old Dec 2, 2007 | 02:12 PM
DVNCI's Avatar
DVNCI
Same here.
Old Dec 2, 2007 | 03:27 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Why do you want 4.56?
Lower is not necessarily better. It needs to match up with the power band of the car and what you plan on using it for.
I bet you'll lose time in the 1/4 with 4.56 gears, your gas mileage will suck, freeway driving will be noisy, and around town drivability will include way more shifting or skipping gears.
Old Dec 2, 2007 | 03:54 PM
DVNCI's Avatar
DVNCI
Well said.
Right now in the 1/4 I am just about to run out of 4th gear at the end so the 4.10's are perfect, until I add more power. And then I'll need LESS gear, not more.
I forget the ratio but the new Z06's have a fairly high gear (low numerically) in the rear don't they? Same thing with the Viper I think.
Old Dec 2, 2007 | 04:34 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I remember reading years ago that the optimmum drag racing gear is around 10 to 1 (first gear times rearend). With the 700R4/4L60 that would be around a 3.3 rearend ratio. With the stick it would 4.00 gears.
HMMM, someone was pretty darn close years ago.
You have to think what the ratio will go to speed and rpm wise, then how second gear will hit, wether it bogs it down (kinda like the 700r4/4L60 does) or pulls hard.
To 4.56 Gears
Old Jun 26, 2016 | 02:08 PM
GS737's Avatar
GS737
6th Gear
Default 456
A lot of comparisons on 1/4 mile. Ours shortened to 1000 feet then 1/8 mile. No one around here runs 1/4 anymore. 1/8 mile is about standard. Anyone have data on 1/8 mile with dana 44 4.10 or 4.56 gear sets
Old Jun 26, 2016 | 04:16 PM
WVZR-1's Avatar
WVZR-1
Everything is relative, the transmission gear, tire dimensions and the rear axle. There's many different answers for you - none are definitive - the only guy who might understand is the "winner" - the guy who lost only knows that either he, the equipment or maybe both ain't gittin' it!!
Old Jun 26, 2016 | 04:59 PM
383vett's Avatar
383vett
Another 9 year old thread makes a comeback
