From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It's not engaging the pin on the oil pump drive. Notice the cam gear teeth cause it to rotate clockwise as you drop it in. So try turning the oil pump drive slightly clockwise with a long screwdriver (about one tooth worth) and then try dropping it in again.
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
That's what I thought. EIther that or take the retainer off the cam and pull the cam forward a little bit....
Where do I turn the oil pump? I have to take the intake off? Please say no...
Just pull it out a little, turn the rotor and let it drop. Keep that up until it sits down. If you are at TDC then that is where #1 will be and run your wires from there.
Old school but it works
By that he means pull the distributor up just a little, and try again. You might have to turn the rotor slightly to a different position (just enough to allow the oil pump drive to engage).
No, just stick a long screwdriver in there through the hole. I was trying to avoid gettting the distributor in a tooth off. If you do, you have to turn the distributor a bunch to get your timing right, and there's not much room on these to rotate the distributor that much.
Quick question, if you accidentally put the distributor in 180* off, can you simply remove the rotor and install it backwards? I recall the plate it screws to allows you to install it either way.
The rotor is keyed so it only fits one way.
I had the timing marks at 12:00 and 6:00, and lined up to cyl 1. I'm good to go.
Yes you can.
You need to just take a dremel and notch the other side.
But if you're going to go through all that hassle, why not just remove the distributer bolt, pull it up and point it in the right direction?
Wouldn't take anymore time to do then messing with the rotor.
i agree.. long screw driver and rotate from top till distributor drops in. i had to do this severals time to be sucessfull
The easiest way next time is to push down on the distributor and bump the engine with the starter. It will drop right down. Honest! Later! Frank
Never do this. I learned the hard way once. It may work if you are lucky, but I did this and sheared the teeth off of the cam. That was a few years ago and I definitely learned an expensive lesson.
