1989 Injector problem?
Old Dec 12, 2007 | 02:08 AM
phade's Avatar
phade
I am loosing what doesnt look like tranny fluid-lol. Its kind of greyish. So what stops the tranny fluid from getting into the intake?
Old Dec 12, 2007 | 10:04 AM
rick lambert's Avatar
rick lambert
Tranny fluid getting into the intake?????? Never heard of that one before....and I doubt it can. Phade, you need to first trouble shoot the fuel system, and then do a leak down or compression test. What does the engine oil look like and smell like?
Old Dec 12, 2007 | 10:13 AM
lambremont's Avatar
lambremont
Originally Posted by Mark_Sheehy
What are you talking about with "injector filters"? There is a main fuel filter along the frame, but not individual filters on every injector. It is the windings that can degrade inside the filter and then they short out, but your ohm readings are fine, so this is not the problem.
Mark, Look at the cross section image of an injector. You will see the filter.
Old Dec 13, 2007 | 12:35 AM
phade's Avatar
phade
Well from what I hear there is a valve on the tranny that has suction from the intake, when that valve goes bad it pulls in tranny fluid. A lil gas in the oil. I think I might have a bad fuel pressure regulator and sucking tranny fluid as welll.
Old Dec 13, 2007 | 09:41 AM
Sam Lam's Avatar
Sam Lam
When I attempt to view the above web site, I only get a blank page. Can others see the image
Old Dec 13, 2007 | 11:01 AM
rick lambert
I couldn't see anything either Sam. I'm really curious to see what he's refering to. I know the old Multechs were designed differentlty, hard to explain, but I have an idea what he's refering to, if I'm right it's not a filter.
Old Dec 13, 2007 | 12:08 PM
lambremont's Avatar
lambremont
Rick, If you will send me your email, I can email the diagram. I'm having trouble getting it on this website.
glambremont@comcast.net
Old Dec 13, 2007 | 12:22 PM
rick lambert
here it is r.w.lambert@att.net
And you can always click on a members profile....it allows you to email messages here.
Old Dec 13, 2007 | 02:17 PM
rick lambert
I'll be damned, Jerry emailed me and sure enough the injectors (Multech) have a filter in the top. Learn something new each day.
