What determines tach redline?
Old Nov 22, 2001 | 04:35 PM
Nitro Junkie's Avatar
Nitro Junkie
Default What determines tach redline?
When I run hard, my tach redlines before every shift. How accurate is the digital dash, and what determines the redline? Valve float? Bottom end? Do you think the engine is actually at redline? Will this hurt it?
Thanks in advance
Old Nov 22, 2001 | 04:47 PM
scorp508's Avatar
scorp508
Our digi-dash tach is truthfully not all that accurate at WOT. I think redline is a combination of many things put together, so I won't even try to explain it. :)
Old Nov 22, 2001 | 04:58 PM
grumpyvette's Avatar
grumpyvette
Default Re: (scorp508)
your REDLINE is basically determined by the valve float rpm and the strength of your engines bottom end, for most cheveys running stock or nearly stock lower end components 4000feet per min. of piston speed is a limmit you should not exceed, yes you can get away with it SOMETIMES but sooner or later that engine will fail if you do!
example: 4000fpm +48000 inches travel for the piston so your 350 has a 3.48" stroke x 2 for each revolution=lets say 7" so 48000/7=6857 rpm max but of course if your engine floats the valves at a lower rpm then that rpm is your redline!
Old Nov 22, 2001 | 05:16 PM
NoWorries's Avatar
NoWorries
Default Re: What determines tach redline? (Nitro Junkie)
My car outruns the tach like crazy, I have the stock governor in the tranny and so I know its shifting right at 4,900 rpms, right where I drop below 400 lbs of torque, so I'm pretty happy with this setup.
The weakest part of my engine is the lifters, which redline at 6,200 rpms, but I'll never take it that high. :eek:
Old Nov 22, 2001 | 08:03 PM
L98Terror's Avatar
L98Terror
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Default Re: What determines tach redline? (NoWorries)
Hmmmm I still have the stock lifters and I shift at 6250 for my fastest runs
Old Nov 22, 2001 | 08:52 PM
CFI-EFI's Avatar
CFI-EFI
I echo the above concerning the stock tach and rpm limits imposed by the valve train and bottom end. Even with a ported intake, you shouldn't WANT to tax it's rpm limits. Now, with some additional modifications, that may change.
Old Nov 22, 2001 | 08:53 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: What determines tach redline? (L98Terror)
I know my tach is off, I shift past 6,000, but in reality, I think it's really 5500.
To What determines tach redline?
