Bought an old Vega drag car. 355 roller small block. Engine runs great. Tore it down just to have a look at bearings etc. Everything looks good. Has heavy duty rod bolts but, considering the low cost, I thought I might as well replace them. Do I have to have a machine shop press them in and out or can I change them myself? Thanks!
Every professional recommendation I've seen in the rod bolt changing procedure says to have the big end resized when the bolts are changed; that you shouldn't just remove the old ones and install the new ones.
Perhaps that is the best, most bullet-proof way to install new bolts, but I've also seen, and have used an alternative method and so far have never had a problem.
It involves leaving the rods bolted to the crank and removing and installing only one bolt at a time. The crank serves as a mandrel to maintain the shape of the big end. The bolt is tapped out and new ones installed with light blows of a hammer. Care must be taken to insure the new bolt goes in straight so that the head sits properly in the rod.
Hope this helps.
Jake
I'm specifically NOT recommending this method though, because of the possibility of losing a rod bearing down the road.
