bumper
Old Dec 4, 2007 | 11:08 PM
FINWNDR's Avatar
FINWNDR
Cruising
Default bumper
HI HAVE 84 AND I LOVE IT WANT TO PUT ZR-1 BUMPER ON IT ??? HOW BIG OF A JOB IS IT & CAN IT BE DONE ?????
Old Dec 5, 2007 | 08:35 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Sitting here wondering why people like to type in all caps?
You can't put a ZR1 bumper on an '84. The ZR1 is much wider.
You can however, put the bumper panel from a late model that had the same style as a ZR1. I believe they started in '92
I haven't done it, so can't say how much work it is. But it can be done.
Old Dec 5, 2007 | 09:08 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Prepare to loose some skin. As RollaMo stated you use either the aftermarket glass "ZR1" style or the 91 up bumper with the third stop lamp in the tail. They bolt on the same as your old bumper 6 10mm nuts on each side, and 7 7mm screws along the top, two 10 mm at the license plate and two more under the rear lower lip(numbers are appox.). Some trimming of the bottom corners of your old "egg crate" inner structure may be required. Remove the inner fenderwells and all the rear lamp assemblies to access the nuts/screws. A word of caution, the replacement bumbers usually are a pain to align to the rear fenders some time, and sometimes there is an 1/8" difference in the width due to shrikage of the 91up unit or the way they make the fiberglass.
To bumper
