I've only had my 94 for about a week now and notice past few mornings when taken off, if i accuralate to quick its very sluggish, almost like its stalling out, but once car wrams up it runs fine, just courious if this is normal, or somthing i need to have checked out, any advise give would b greatly appricated,
it could be that it runs better once it gets warm and goes "closed loop" and is using the O2 sensor to adjust fuel ratio.
try adding some "fuel injector cleaner" to the fuel tank.
its a good idea to do this once or twice per year (if you drive it alot).
sounds like the injectors might be dirty.
make sure its for "fuel injection" not just carb cleaner.
also check throttle body, it might need a cleaning. Air filter too.
but if you want to give the fuel injectors a cleaning try Sea Foam or if you can get the BG products stuff i like that too... its pretty good and all you have to do is add it to the tank.
