headliner
Old Dec 6, 2007 | 01:50 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default headliner
Hey guys
Just wanted to say I fixed my headliner, and I've been putting it off for almost a year. I was dreading the whole roof "rebuilding" process. I finally got fed up with the thing looking like the inside of a poorly stretched circus tent. It turned out to not be bad at all.
I have a sharp looking headliner, and it took me almost an hour plus the 3 minutes to remove it and the 3minutes to put it back on.
What I did was to pull the headliner material out from around the circumference of the roof without pulling the front material out.
I got some red scotchbright, and rubbed the old 1/8 inch foam till it turned to powder, and vacuumed it all up.
Then I carefully vacuumed the headliner material of all the old glue.
vacuumed the pad one more time, and lightly sprayed 3m glue on the pad, and started from the center front, pressed lightly until the whole headliner was adhered to the pad except for the edges, and I used a super thin spatula (yes from the kitchen) with round edges, and poked the material back into place.
looks awsum!!! took less than an hour.
I had the can of spray glue left over from another project, so the cost was almost zero, and it's the original material.
Old Dec 6, 2007 | 02:57 PM
runner140*'s Avatar
runner140*
Originally Posted by coupeguy2001
Hey guys
Mine started to sag....I could feel it touch the top of my head. I cut three sides, used 3M adheasive and stretched and rolled the material back into place. Then tucked excess under the frame.
Old Dec 6, 2007 | 04:40 PM
rube1975's Avatar
rube1975
i got to do that to my hard top.
quick question though
can you get a foam insert or something to that extent of a C4 symbol??
i though i saw one but it may have been a dream.
Old Dec 6, 2007 | 05:51 PM
DonF's Avatar
DonF
You made it sound easy, I have to do it on the 96 I just bought. The previous owner put tacks in it, whoo ha, he had some taste.
Old Dec 6, 2007 | 06:06 PM
Bob CTS's Avatar
Bob CTS
Chris,
Awesome job, I had to fabricate a whole board in the 86 because the fiber board in mine was completely shot. It annoyed the hell out me when the fabric was hanging down.
Old Dec 6, 2007 | 11:01 PM
rrubel's Avatar
rrubel
You can buy headliner material (cloth glued to thin foam) at fabric or craft stores (I use AC Moore). That, a can of "Heads Up!" glue, and 45 mins fixed the liner in my 86. I tried just gluing the drooping fabric back in place, but the glue showed through the weave after it dried and it looked messy.
[RICHR]
To headliner
