Newbie Needs Info About ECM Location
Old Dec 6, 2007 | 02:28 PM
Captain Hayes's Avatar
Captain Hayes
Navigator
Default Newbie Needs Info About ECM Location
Being the owner of a 1995 Base Corvette with the LT1 engine for all of two months, I'm ignorant of a lot of things.
I have a message that flashes next to my speedometer - it flashes "SYS".
Judging by the conversations I've seen by lurking, I assume that it means I triggered a code. Okay, I bought an AUTO X-RAY EZ Read 2000 scanner. It came with 4 connectors but the owners manual states that some 1994-1995 GM and Fords have an OBD II interface but use OBD I protocols. How would I know if it uses the OBD I protocols?
So no flaming please - I have used the search feature and haven't found the info that I need. Just where is the connector located for me to hook up my Scanner?
Also, while I was installing a new sound system I saw a large connector hooked to a long cable in the compartment behind the drivers seat. Just what is this connector?
I've tucked the Vette in the garage for the winter so I can take my time in reading the codes and repairing the problems.
Thanks for any information/advice that others can share with me.
Old Dec 6, 2007 | 03:25 PM
STL94LT1's Avatar
STL94LT1
All 1994/95 Corvettes have OBDI PCMs with OBDII ALDL connectors.
There is a pretty good possibility your flashing "SYS" is caused by your new sound system.
Your PCM is located in the left side engine compartment right above the battery.
Old Dec 6, 2007 | 03:31 PM
Captain Hayes
Navigator
Okay, thanks for that info, but I need to know something even more basic (I wasn't kidding about being ignorant about this stuff) - where is the connector to plug my code scanner into?
Old Dec 6, 2007 | 03:34 PM
STL94LT1's Avatar
STL94LT1
The ALDL connector is located under the driver's side knee bolster. Just above your right knee, when you're seated in the driver's seat.
Old Dec 6, 2007 | 03:35 PM
STL94LT1's Avatar
STL94LT1
FYI: Do a "search" on stereo installation and the flashing "SYS".
Old Dec 7, 2007 | 09:44 AM
kalister1's Avatar
kalister1
The compartment behind the drivers seat houses the ASR/ABS unit. The compartment behind the passenger seat houses the radio receiver, if you have the Bose system.
Old Dec 7, 2007 | 09:52 AM
Captain Hayes
Navigator
Thanks to the people who have given me info.
Another thing I found was a long thin cable that comes from one of the rear compartments, goes by the console on the passenger side. The cable terminates with a head that has two telephone-type connectors. I don't see anything in my Haynes book about this cable.
Old Dec 9, 2007 | 01:38 AM
94vetten73stang's Avatar
94vetten73stang
I've read about that extra connection by the console in the owners manual. it is for a phone hook up for a cell phone or something like that, its an accessory plug.
Old Dec 12, 2007 | 11:30 PM
DHealey's Avatar
DHealey
I had the SYS flash a few years ago, it was the battery giving up the ghost. Replaced and never had the light again.
Old Dec 13, 2007 | 08:57 AM
VenkmanP's Avatar
VenkmanP
There were no RJ11 connectors in your car when it left the factory.
If you want to understand the car you need a real service manual not a Haynes.
I did a quick search for threads in this section with "1995" in the title, and found several threads that would answer most of your OBD-related questions. Other relevant search terms would be "OBD2" "OBDII" "OBD1" "OBDI" and "ALDL"
To Newbie Needs Info About ECM Location
