C4 Front Spring Info? HELP!!!!
Old Dec 7, 2007 | 11:10 PM
tommyn's Avatar
tommyn
St. Jude Donor '06
Default C4 Front Spring Info? HELP!!!!
I am building a 57 Belair on a Paul Newman Carcreations chassis. I am having issues with the ride height. I was told the used spring I have installed may be part of the issue. The Spring ends @ the A arm are square pads not the typical pie shapped. The rubber end not the spring itself. GM # 17986459. I was told this is a one year only spring? Anyone have any idea what the spring rate on this is? The other suspension parts have a 94 date if this helps. I would like to know so I can order a new VBP spring but want a starting point.
Thanks for any help. Tommy
Old Dec 7, 2007 | 11:55 PM
rodj's Avatar
rodj
What is the code stamped on the spring?
something like FHA
Old Dec 8, 2007 | 02:08 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
My C4 parts book does not show any use of that spring p/n, but it does appear to be a legit number since there are similar numbers for the 91-96 springs. Maybe its a service replacement spring. Those tend to have different part numbers.
Old Dec 8, 2007 | 10:58 AM
tommyn's Avatar
tommyn
St. Jude Donor '06
something like FHA
Yes FHA I was told is the manufacturer.
That's what I was finding as well. Chevy is no help, number has been purged. A chassis guy said it is a GM spring.
Old Dec 8, 2007 | 11:19 AM
Aardwolf's Avatar
Aardwolf
My chart shows FHA 93.1 n/mm. Yes it's GM. To change ride height with the spring in a Corvette we cut the pads on the ends and change the mounting height on the middle brackets.
Old Dec 8, 2007 | 01:28 PM
96GS#007's Avatar
96GS#007
FHA is not a manufacturer. FHA is a spring code the correlates to a spring rate.
Are you trying raise or lower the ride height?
Was the spring new or used when you got it?
It sounds as though you bought a used spring and a prior owner trimmed the pad off each end to lower the ride height.
Old Dec 8, 2007 | 02:06 PM
CentralCoaster
I didn't know the later springs had pads on them. There's one for sale in the C4 section with no pads on it. Or were the pads a seperate part?
Old Dec 8, 2007 | 04:46 PM
96GS#007's Avatar
96GS#007
The later springs have a pad that is glued to the tip. It's about an inch thick. Not unusual for people to trim the pads off to lower the front.
If I get a chance, I'll upload some pics of mine later today or tomorrow. Added pics. Gotta look close to see the pads. Also included a pic of a couple pads I trimmed off. The spring with lots of arch is a 1996 base suspension spring from my GS. The other is the VanSteel Z51 spec spring. Hats off to VanSteel/Hyperco (mfg), awesome quality spring.
Full size
http://www.digitalcorvettes.com/corv...comparison.jpg
Old Dec 8, 2007 | 09:13 PM
tommyn's Avatar
tommyn
St. Jude Donor '06
What chart? Under the FHA is 15. I have added shims to the middle mounts and added a shim under the spring ends. This changes the ride height for a time but only a little for the amount of shims. When the car settles it seems like no change.
The car is sitting to low. I am getting tire rub on the fender lips.
Used front and rear parts from a salvage yard. I saw the car they came off of and it was a theft recovery missing the drivetrain, not a wreck.
The pads are there, just not what I have seen in the catalogs.
Full size
Mine looks like the stock spring.
Old Dec 9, 2007 | 02:18 AM
96GS#007's Avatar
96GS#007
What engine are you running in the car? I'm guessing that there may be too much weight up front for the Corvette springs.
You'll need add shims on top of the rubber spring mounts that are towards the center of the spring. If you're using a Corvette mounting method, GM sells shims or you can cut them out of aluminum to the thickness you desire.
Old Dec 9, 2007 | 02:43 AM
rodj's Avatar
rodj
"What chart? "
Reading material
http://forums.corvetteforum.com/show....php?t=1284264
Old Dec 9, 2007 | 08:23 AM
tommyn's Avatar
tommyn
St. Jude Donor '06
LS1, this should be ok for the stock suspension. I have added close over an inch of shims to the center mounting points.
tommyn's Avatar
tommyn
St. Jude Donor '06
Great link thanks!
Old Dec 10, 2007 | 10:35 AM
96GS#007's Avatar
96GS#007
The LS1 isn't hurting Could still be a weight induced issue. Steel body?
An inch of shims isn't that much. My Vette had nearly 3/4" of shims from the factory with the base spring and it sat pretty low in the front.
How much do you need to raise the ride height?
Old Dec 10, 2007 | 11:29 AM
tommyn's Avatar
tommyn
St. Jude Donor '06
Steel body yes.
I have added shims until I could not add anymore! I need another 1/2 to 3/4 inch for no tire rub issues.
Old Dec 10, 2007 | 01:03 PM
96GS#007's Avatar
96GS#007
Steel body yes.
Some other options...
- Add a pad to each lower control arms.
- Buy wheels with a different offset in order to tuck them into the fender wells
- Relocate/change the spring/chassis mounting points to move the spring downward. Are you using the entire C4 frpont suspension cradle?
- Try a different spring (might end up in the same boat)
Old Dec 10, 2007 | 02:50 PM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Default Springs
Hi Tommyn,
If you need some help, please do not hesitate to call my techs, Gary or Steve, toll free at 1-800-237-9991. If you can give us the total weight of the car, your issues and what you want to accomplish, we can set you up in just the right arch style and spring rate to get you just where you want to be. We manufacture alot of different arch styles for various applications and kit cars. We also manufacture them in many different rates to fit the weight and driving style.
All of our springs are on sale from now until the end of the year too. If you cannot get the one you have to work, please feel free to call us.
Best Regards,
Pattie Cooke, Sales Mgr.
VBP (Vette Brakes and Products)
To C4 Front Spring Info? HELP!!!!
