Rear window grid
Old Dec 8, 2007 | 09:39 PM
Dads90's Avatar
Dads90
Default Rear window grid
Does anyone know if the rear window grid gets warm enough to feel ? The test from the FSM shows its OK. I don't have any visible broken grid lines. The connections on the struts are fairly tight. But one wire that is soldered to the window grid is kinda loose, has a few wires that broke free but is still connected. My windows get hot to the touch, but not the window grid. Any thoughts ?
Old Dec 8, 2007 | 11:17 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
FWIW if a single line gets broken it will only kill current on that line, and the rest should still work.
Old Dec 8, 2007 | 11:46 PM
Dads90's Avatar
Dads90
Oppps, I going crazy here, the rear view mirrors get hot to the touch, (just reread my post). I know at least they are working.
Old Dec 9, 2007 | 08:06 AM
comp's Avatar
comp
to hot to touch ??
Old Dec 9, 2007 | 12:44 PM
Dads90's Avatar
Dads90
No, they are very warm
Old Dec 9, 2007 | 01:38 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I've never really paid much attention to how hot the glass got.
Remember though, the mirrors are a lot smaller surface area than the rear hatch. I really doubt the rear glass is ever going to get "warm" enough for you to actually feel it.
It only has to get warm enough to melt ice (32 degrees F.). And even then, it's not like it melts it instantly. It will take awhile.
Old Dec 9, 2007 | 07:21 PM
Dads90's Avatar
Dads90
Since it doesn't get cold that much down here, I only turn it on during damp foggy conditions if the car has set out overnight. I used to see the grid clearing the fog, but I guess it needs to be colder.
Old Dec 9, 2007 | 07:36 PM
ynk1121's Avatar
ynk1121
the easiest way to tell if all the lines are working is to spray a very light mist of water on the glass. You want the drops of water tiny enough that they don't blob together and drip down. If you have a line out they sell repair paint.
Old Dec 9, 2007 | 11:02 PM
Dads90's Avatar
Dads90
Thanks I'll give it a try.
To Rear window grid
