Where do I start?
Before i replaced plugs,wires,rotor,cap... the car had no throttle respose, well not what I am expected any way.Just bought the car, it has 160,000 miles on it. So did the changes and now the car at idle dips to 500 rmps at times, then idles normal after feathering the throttle up to 750 rpms or so.
Hold the throttle steady about 1200 rmps under NO load,rmps dip to 1000 then back up, this will not stop. It will happen cold or hot.
And last when you try to take off the car will buck if rpms are below 1200... NO CEL Clean MAF and new fuel filter...
Once car is rolling about 1200 it will run smooth.
Got any ideas?
Corey
I would check your timing, TPS and min idle. Search for vacuum leaks, also.
89 injectors are also known for causing problems like yours. May be time for new injectors ?? Use the search engine for more info on your injectors. Here is a write up on setting the TPS and min idle. https://www.corvetteforum.com/techti...D=55&TopicID=2
WARNING!!! The tech tip above contains an error which will not allow proper adjustment of the min air or base idle adjustment. This procedure does NOT include an important step which is disconnecting the EST connection (tan colored wire located at rear of drivers side valve cover). If the EST connection is not opened, the ECM will adjust the timing in an effort to achieve the desired engine RPM and the manual adjustment will not be accurate.
I attempted to get the author of the above tech tip to modify the procedure a few years ago and he would not agree to make the change.
Here is a similiar procedure from the C4 grand master, Gordon Killebrew on the same topic. Note the statement (item #3) on opening the EST!
The TPS And IAC adjustment procedures written up by Lars was (IIRC) well-received when it was posted. But Gordon Killebrew is the Guru of all things C4 so I would trust his write-up.
One thing that Gordon's write-up does not show is when the EST wire is re-connected. Is it done before setting TPS voltage or after? Obviously you have to do it before clearing the Code 42 but
What's strange is that my 87 FSM does not specifically state to unplug the EST wire before setting TPS voltage.
My 89 FSM has a statement that is preceded by the word IMPORTANT and it describes what can happen if the connecttion is not opened BEFORE the procedure. As for reconnecting the tan wire, the Killebrew procedure did not mention this step??? However, the tan wire should be reconnected before a battery cable is removed to clear the ECM code. This connection does not relate to the setting of the TPS.
Thank you for the help. I have read both articles and I will attempt to do the adjustment tis afternoon.
I have not worked on an american car for so long that I have forgotten a lot.
I take for granted the whole electronic tuning with a computer and an obdII imports.
It would be a good idea, before you do the above, to remove the IAC motor and clean both the IAC and the IAC passages in the TB. Make sure you retract the pintle before re-installation.
cscg2340: When you have a few minutes to spare, please consider updating your profile. This info is very helpful to forum members who are trying to help you. If you have questions on this, please post them
Well I haven't had any luck yet.
Car seems to run a little different now, but not right yet.
No CEL
new Burn off relay
tps .549
idle won't really stay at 450 while doing adjustments, so did the best I could around 500
Car seems to be fine while in the throttle
The problem I have now seems like a vac leak, idles up and down while rolling, and kind of dips while stopped, but not like when the clutch is in while rolling, but if I hold a steady throttle anywhere and the throttle dips, then back up.
I am going to try replacing the cap and rotor again, and look for vac leaks.
Gonna keep pluggin away...
Just for whats its worth, don't forget to check for a vac leak in the power brake booster. The diaphrams go bad sometimes and a vac leak is hard to detect in this area.
