Would A/C Comp. need to be removed?
Old Dec 9, 2007 | 06:01 PM
rg951's Avatar
rg951
Default Would A/C Comp. need to be removed?
Got a simple question....but since my car is in the shop...I can't simply look under the hood.
My car is in the shop for a blown head gasket. They removed both heads & are in the process of rebuilding them before reinstalling a new head gasket.
Would they have to remove or disconnect the A/C compressor for this?
Reason why I ask....is that my a/c probably needed a recharge. I figure if they had to automatically remove the a/c...they would recharge it as they reinstall the heads. I can call & have them 'check' the a/c...but didn't want to get billed for something if it could be avoided or if it was unnecessary.
94 C4 LT1
Old Dec 9, 2007 | 06:08 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I beleive they have to remove the compressor from the bracket, but they do not have to disconnect the lines.
At least thats the plan for my 92 when I do it this winter.
Old Dec 9, 2007 | 06:24 PM
Aardwolf's Avatar
Aardwolf
That is what I do with my '88.
Old Dec 10, 2007 | 03:17 PM
JCD's Avatar
JCD
yup, unless they're ignorant they'll leave it connected, no freebie for you.
Old Dec 11, 2007 | 10:51 PM
rg951's Avatar
rg951
Thanks all. It's hard to know w/o the car being here.
I figured as much
Old Dec 12, 2007 | 09:55 AM
DonF's Avatar
DonF
Even on an engine pull there is no need to disconnect the lines, they are long enough to pull the AC comp. to one side.
To Would A/C Comp. need to be removed?
