On a batch fire system 4 injectors fire at the same time right. If that's the case what does the fuel do once it's been shot or injected? does it sit in the runners? Or does is it still suspended in air because the event happens so quickly? I have always wondered about this because the ignition doesn't batch fire so what does the fuel do while it's waiting to be drawn in it seems to me that this would not be very efficiant. Do all EFI systems do this or just TPI? could a person put a delay on the injectors for the cylinders that are not quite ready for fuel and gain performance through efficiancy?
Yep, it just sits there. Later TPIs went with sequential fire.
I think all TPI's were batch fire as well as the first LTx. Later in the LTx production (95?), they went to sequential fire. It's not a big deal because the fuel is in vapor form. Under certain circumstances, the fuel can condense out and puddle (really cold engine with cold-start enrichment), but in normal operation you shouldn't see this happening.
The bigger benefit of sequential-fire is more control over individual cylinder mixture rather than the fuel timing itself.
we have used CONSTANT flow injectors (hilborn, algon, kinsler,etc) on drag and circle track racing engines for many years with NO electronics...top end performance is great, idle is ok...for emissions, a true ''sequential'' system helps at ''idle'',batch flow is a ''half measure'' at reduced complexity/cost/emission reduction.
If you do a little math you can see its not a big deal. At 600rpm an intake valve opens every .2 seconds. That's the longest the fuel would "sit there".
Makes sense, so what is the benefit of sequential?
Smoother idle and better emissions. On batch fire engines, you often have to make it run richer at idle to get it as smooth, which isn't as good from an emissions perspective.
Wow you guys sure know a lot of stuff, any way thanks for the info
And Paul Ruggeri you vette looks cool cornering ahead of that newer model, did you overtake him or is he going to pass you?
I wish I could say I just blew past those guys, but no such luck. With 100+ hp less, I don't stay in front for long . Still its the most fun you can have with you Corvette
